Go to Post They may call us geeks and nerds, but deep down under that prejudice they know they want to be the hard-core, sleep-deprived, hand drill-toting, robot builders we know we are! - vijay24 [more]
Unread 08-02-2011, 14:57
falconmaster's Avatar
falconmaster falconmaster is offline
AKA: Ledge
FRC #0842 (Falcon Robotics)
Team Role: Teacher
falconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond repute
Send a message via MSN to falconmaster
Dulce's First tele-op tube
Here is our first test of the prototype arm hanging a tube.
http://www.youtube.com/watch?v=N415TOE45Fk
We are building a gearbox to hopefully give the arm more torque
Faridodin "Fredi" Lajvardi KD7WKD
Unread 08-02-2011, 15:11
Josh Fox Josh Fox is offline
AKA: Foxy
FRC #0027 (Team RUSH)
Rookie Year: 2007
Josh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud of
Re: Dulce's First tele-op tube
We had issues with torque on our "virtual four-bar" (I think that's the term) last year. We were putting it under considerably more load (trying to elevate our robot), but we were never really able to explain where our mechanical losses were coming from.
It got to the point where #35 chains were breaking and hex shafts were shearing before we threw in the towel on it, but I was just wondering if you guys had any insight as to what sort of mechanical advantages/disadvantages go into an arm like this? I've been curious about the math behind it ever since.
It looks like your gripper is pretty solid and not too finicky about the orientation of tubes it's trying to pick up. I also love the geometry the arm goes through, this is such a cool concept. Good luck!
Team RUSH Alumnus and Mentor, Mechanical Engineer
Unread 08-02-2011, 15:16
Michael Corsetto's Avatar
Michael Corsetto Michael Corsetto is offline
Breathe in... Breathe out...
FRC #1678 (Citrus Circuits)
Michael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond repute
Have you considered sticking a gas shock between the upright and first segment of the arm?
Awesome design, way to get it working, can't wait to see the final result!
Team 1678: Citrus Circuits - Lead Technical Mentor, Drive Coach **Like Us On Facebook!**
Unread 08-02-2011, 15:22
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
4-bar mechanisms can benefit greatly from the use of supporting springs. One of the designs our team originally considered was a 4-bar mechanism, and to help demonstrate it to the team, I brought in an old desk lamp that utilized that mechanism. The lamp in question had several springs stretched in place, and one of the more interesting parts of investigating how it worked was moving it with and without the springs in place. With the springs, it was easy to lift up, and it held its position perfectly. Without the springs, it was a lot harder to lift, and would drop back down immediately.
I would highly recommend looking into how springs could be used to help provide the added torque needed to neutralize the weight of the arm, allowing your motor to work a lot easier.
Unread 08-02-2011, 15:28
thefro526's Avatar
thefro526 thefro526 is offline
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
thefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond repute
Send a message via AIM to thefro526 Send a message via MSN to thefro526
Torque issues aside, that arm looks fantastic.
Is it just me, or does the gripper stick out past the chassis on one side? I'm assuming this will be fixed down the line?
-Dustin Benedict
2005-2012 - Student & Mentor FRC 816
2012-2014 - Technical Mentor, 2014 Drive Coach FRC 341
Current - Mentor FRC 2729, FRC 708
Unread 08-02-2011, 15:30
Chris is me's Avatar
AKA: Pinecone
Are you concerned that your arm will get caught up on the bumper when pulling up / back?
Unread 08-02-2011, 15:37
kgzak's Avatar
kgzak kgzak is offline
AKA: Kris
FRC #4392 (Decievers) FRC #2075 (Enigma)
kgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to behold
Is the arm fully inside the robot when it is up? It looks like it might be but The tube blocks the bottom of your gripper. Also can you reach the top peg?
Otherwise it looks nice. Hopefully I can get video of our lifter up soon
Unread 08-02-2011, 15:52
AKA: Ledge
Team Role: Teacher
It is adjusted for the bumper.. . will have that on soon
Unread 08-02-2011, 15:51
AKA: Ledge
Team Role: Teacher
Its a prototype. We will fix the dimension issues.
Unread 08-02-2011, 15:54
MrForbes's Avatar
MrForbes MrForbes is online now
AKA: Jim
FRC #1726 (N.E.R.D.S.)
I know 842 has gone thru a lot of calculations to figure out what size and how long of latex springs to use. There might be more friction in the arm than anticipated...although I think the joints use ball bearings.
It's neat to see it running at last! I know they'll get it sorted out...hopefully I'll get to see it Feb 19 at Duel in the Desert
Unread 08-02-2011, 15:15
billbo911's Avatar
billbo911 billbo911 is offline
I prefer you give a perfect effort.
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
billbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond repute
Looks like you are on the right track.
You are spot on about needing more torque. What are you currently using for a motor and transmission? What is the load on the mechanism as it is built right now?
CalGames 2009 Autonomous Champion Award winner
Sacramento 2010 Creativity in Design winner, Sacramento 2010 Quarter finalist
2011 Sacramento Finalist, 2011 Madtown Engineering Inspiration Award.
2012 Sacramento Semi-Finals, 2012 Sacramento Innovation in Control Award, 2012 SVR Judges Award.
2012 CalGames Autonomous Challenge Award winner ($$$).
2014 2X Rockwell Automation: Innovation in Control Award (CVR and SAC). Curie Division Gracious Professionalism Award.
2014 Capital City Classic Winner AND Runner Up. Madtown Throwdown: Runner up.
2015 Innovation in Control Award, Sacramento.
2016 Chezy Champs Finalist, 2016 MTTD Finalist
