Go to Post Unconventional isn't necessarily innovation. - AdamHeard [more]
Go Back   Chief Delphi > Technical > CAD > Inventor
Unread 08-02-2011, 17:39
joek's Avatar
joek joek is offline
Team Welder and CAD tech
FRC #2052 (KnightKrawler)
Team Role: Mechanical
joek is an unknown quantity at this point
Importing error
I can import .STEP files with no problem, but Pro/Engineer files do not import at all
"Translation failed. Pro/ENGINEER unauthorized File Type."
2012 Record (13-2-0)
lake superior regional finalists- thank you WAVE (2826) and Blue Twilight (2220)
Unread 11-02-2011, 14:58
joek's Avatar
Re: Importing error
hello? anyone home?
Unread 12-02-2011, 08:36
JD Mather's Avatar
JD Mather JD Mather is offline
JD Mather is a jewel in the roughJD Mather is a jewel in the roughJD Mather is a jewel in the roughJD Mather is a jewel in the rough
Re: Importing error
Can you attach a sample file here that you can't open?
Is the Pro/E translator active in Toosl>Add-ins?
Did you turn off UAC and anti-virus before install?
When opening click Options and turn off creation of the html report (this causes problems on some machines).
Have you installed Service Pack 1 (with UAC and anti-virus turned off)?
Autodesk Inventor Certified Expert
Certified SolidWorks Professional
AU 2007 Avatech Altogether Smarter Inventor Challenge 1st Place
http://home.pct.edu/~jmather/content..._tutorials.htm
Unread 12-02-2011, 12:04
Duke461's Avatar
Duke461 Duke461 is offline
Boiler Strong.
AKA: Ben Carson
FRC #0461 (Westside Boiler Invasion)
Rookie Year: 2010
Duke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond repute
Re: Importing error
How do you know if you've already installed Service Pack 1?
Thanks,
-Duke
The opposite of excellence is good enough.
2012-2013 President; 2011-2012 Vice President
2011-offseason FRC Student Drive Coach; 2010-11, 2011-2012 VEX Drive Coach
2011, 2010-offseason FRC Driver/Operator
2012, 2011-offseason, 2010-offseason FRC Human Player
Find me on: Facebook, Gmail, Twitter, Tumblr, Blogger/Blogspot
Unread 12-02-2011, 14:21
joek's Avatar
Re: Importing error
it's a fresh install, on XP, 2011 version. i'm trying to convert the FTC KOP
where is this service pack you speak of?
EDIT: the translator was disabled, hopefully that fixes it
EDIT rev2: it crashed
Unread 12-02-2011, 15:33
Duke461's Avatar
Boiler Strong.
AKA: Ben Carson
Rookie Year: 2010
Re: Importing error
service pack can be found here:
http://usa.autodesk.com/adsk/servlet...linkID=9242019
Duke461's Avatar
Boiler Strong.
AKA: Ben Carson
Rookie Year: 2010
Re: Importing error
usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15506670&linkID=9242019
Unread 12-02-2011, 15:47
joek's Avatar
Re: Importing error
I think it was just hardware, running on a 1.5 Ghz single-core cpu and 512 ram
Unread 13-02-2011, 14:55
JD Mather's Avatar
Re: Importing error
Originally Posted by joek View Post
.... 512 ram
...are you sure about that? Minumum specification is 2Gig RAM.
Unread 13-02-2011, 15:42
Duke461's Avatar
Boiler Strong.
AKA: Ben Carson
Rookie Year: 2010
Re: Importing error
While we're on the topic of RAM, Inventor crashes every once in a while at out school. I think the computers have 3 or 4 Gigs of RAM, but the "virtual memory" it stores says something like 1200 MB. Basically it only crashes when im working on the really big files for a long time, but do you know of any ways to help prevent that?
Unread 14-02-2011, 11:11
joek's Avatar
Re: Importing error
i'm sure, and the service pack won't install. uses a lot of virtual memory, 1 or 2 gig's worth.
our school comp's have 2 gig's and I have never had much of an issue w/ crashing, even with our robot files.
Unread 15-02-2011, 14:13
joek's Avatar
Re: Importing error
the service pack also will not install.
Unread 15-02-2011, 19:33
inventor_phild inventor_phild is offline
inventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant future
Re: Importing error
Joe,
Good to hear from you again this year. Let's see if we can resolve the import issue.
Depending on the type of ProE file it may not import correctly. For example, some types of assembly files may have issues and need file renaming and other techniques. However, I have checked all files related to FTC and the field and there were no problems on my machine.
Please email me a single file that is causing a problem and I will check it for you.
With regards to RAM, keep in mind that on a 32 bit system you have to use the 3 GB switch. See the Help file for details.
My machine has 8 Gigs running on Windows 7 64 bit and it sees all the RAM.
Phil Dollan
Autodesk Inc.
Autodesk Inventor and Fusion 360
