Go to Post To me, every robot is a moving mechanical art form, a sculpture made of aluminum, motors and gears, and I think that soon we will be seeing those art forms involved in some of the most fantastic robotic "dances" that any of us have ever seen - DougHogg [more]
Unread 08-02-2011, 21:07
archer003's Avatar
archer003 archer003 is offline
Grease Monkey and Electrician
AKA: M Squared
FRC #1982 (Cougar Robotics)
Team Role: Leadership
archer003 is a jewel in the rougharcher003 is a jewel in the rougharcher003 is a jewel in the rough
Lightbulb Dog Leash Optical Encoder?
Our team is planning on attaching a dog leash to a CiMple gear box in order to make an optical encoder.
Yes, that's right, a retractable dog leash.
The Box allows us to attach the encoder onto the shaft with ease as well as gain the ability to measure the height of our tower. Our programmers are planning on using this on the code.
I was wondering about opinions on this, as well as legality? I can't imagine a standard, off the shelf dog leash being against the rules, and I know but you never know. Thank you!
~M
Team 1982 Cougar Robotics! Have you had your Vitamin-C today?
Unread 08-02-2011, 21:28
Justin Stiltner's Avatar
Justin Stiltner Justin Stiltner is offline
The big guy
Rookie Year: 2000
Justin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud of
Send a message via ICQ to Justin Stiltner Send a message via AIM to Justin Stiltner Send a message via MSN to Justin Stiltner Send a message via Yahoo to Justin Stiltner
Re: Dog Leash Optical Encoder?
Assuming you are using a legal potentiometer, then whatever you attach to it is fine as long as it meets the additional hardware rules.
What you are making is commonly called a string pot. you can get potentiometers that have multiple turns, in that manner you may not need to use the gearbox. A normal pot only turns about 270 degrees, a multi turn pot may turn 10 or more times.
I have used celesco string pots before with good results. They were about $60 per each when we bought them, and would be more reliable and faster than making your own. Good luck!
http://celesco.com/stringpots/index.htm
Justin Stiltner
Lead Robot Inspector, VCU Regional
Unmanned Systems Lab, Virginia Tech
KI4URQ
