Go to Post Because when you build the people and the team, building the robot comes much easier. - Koko Ed [more]
Unread 09-02-2011, 10:30
StorminNormin StorminNormin is offline
FRC #2181
StorminNormin is an unknown quantity at this point
Double sided tape?
We need more traction on our Minibot and want to use double sided tape to attach rubber grips to our wheels.
Is there anything that says we can't use tape?
Unread 09-02-2011, 10:37
Zuelu562's Avatar
Zuelu562 Zuelu562 is offline
Ready for WPI District!
AKA: Jake Janssens
FRC #3623 (Terror Bots)
Zuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to behold
Re: Double sided tape?
HINT: Rule <R92> is the perfect place to find out!
As long as you don't use velcro and the double-sided tape is made of a material that is allowed, it's fair game.
Team Resume
562 "S.P.A.R.K." - Student Programmer 2008-2011, Field Coach 2011
3623 "Terror Bots" - Technical Mentor, Field Coach 2012 - Present
Volunteer Resume:
BattleCry@WPI 12, 13, 15, 16 - Queuing
BattleCry@WPI 14 - Field Reset
Granite State District Event 2014 - Team Queueing
NEFIRST District Championships '14,'15,'16 - Team Queuing
Unread 09-02-2011, 10:39
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
<R92> The following items are the only permitted materials for use on the MINIBOTS:
A. TETRIX components that are not in violation of any other rules, (Tetrix components are listed in Approved Tetrix Parts at www.usfirst.org/frc/competitionmanual),
B. no more than two motors (PN W739083/W739023) and an unlimited number of Tetrix servos),
C. no more than one 12V rechargeable NiMH battery pack identical to those supplied in the FTC kit of parts (PN W739057) except the 20A fuse may be replaced with an equivalent type of lower amperage,
D. No more than one HiTechnic DC motor controllers,
E. No more than one NXT controller with the Bluetooth functionality disabled,
F. Polycarbonate,
G. Polycarbonate glue,
H. Raw aluminum sheet, 90° angle, u-channel, tube, bar, that is not sold in pre-perforated or pre-punched form.
I. rivets,
J. non-metallic rope or cord,
K. wire nuts, solder, and crimps,
L. cable ties,
M. limit switches,
N. no more than two common household light switches,
O. electrical hookup wire,
P. non-slip pad,
Q. PVC or CPVC pipe and fittings,
R. PVC cement or cleaner,
S. Mechanical fasteners (e.g. screws, bolts, etc),
T. Loctite or similar thread-locking product,
U. Rubber bands,
V. Surgical tubing,
W. Electrical tape and shrink tubing,
X. PWM extension cables,
Y. Universal security clips to hold the PWM connectors together,
Z. Hook and loop fastener (may not be used as tape),
AA. Magnets,
BB. NXT compatible sensors and related connectors/cables,
CC. Grease, and
DD. Non-functional decorations.
The list seems to be pretty clear. You can use electrical tape... but that's the only type of permitted tape.
Unread 09-02-2011, 10:51
CrazyCarl461's Avatar
CrazyCarl461 CrazyCarl461 is offline
Power User
AKA: Carl Agnew
FRC #0461 (Westside Boiler Invasion)
Team Role: Coach
CrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant future
Send a message via AIM to CrazyCarl461
I think you would have better results with a 400-series Loctite® anyway, which appears to be legal per <R92-T>.
My 2011 Build Season Blog
Resistance may be futile, but capacitance has potential!
© All content is protected by the honor system
