Go to Post "there are two types of underprivileged teams; the ones who whine about being underprivileged and the ones that work to become privileged". - Undertones [more]
Unread 09-02-2011, 13:55
team3607 team3607 is offline
FRC #3607
team3607 is an unknown quantity at this point
More Dlink problems
I am really starting to get mad at this thing. I have spent many hours trying to get this thing to work. The latest problem is it will not reset and I have a feeling that it is bricked. The power light keeps blinking and when it is set to bridge mode, no orange light appears. Also, when I try going to http://192.168.0.51 the emergency web sever shows up. I followed the steps provided by FIRST (http://www.usfirst.org/uploadedFiles...Web_Server.pdf) to fix that 3 times but it did not work.
I have spent probably around 7 or 8 hours just trying to fix the stupid thing with no luck. Any help would be greatly appreciated.
Unread 09-02-2011, 14:08
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: More Dlink problems
The "emergency web server" page is letting you know that the router has lost its firmware and needs to be reloaded. Concentrate on getting the dap1522_fw_121.bin file uploaded to the router correctly. At what point in the directions does it not do what it should? What does it do instead?
Unread 09-02-2011, 14:13
FRC #3607
I did it step by step and it seems to work. I uploaded the file to the emergency server and it told me to wait so I did. It said it was complete and to restart the device. So I turned the power off. Waited like a minute. Plugged it back in, then tried going to http://192.168.0.50 again but the emergency web server is still there.
Unread 09-02-2011, 16:07
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
My guess is that if the firmware is corrupted, it will go back to the emergency webserver. Have you tried redownloading the firmware? Tried a different computer? Tried a different ethernet cable?
Unread 09-02-2011, 17:25
FRC #3607
I downloaded the file FIRST told me to. Unless there is a different firmware to download, I reinstalled it like 5 times. I have tried the laptop and 2 other computers. Same thing happens and I have used an ethernet cable as well as a crossover cable. Same thing happens.
I read somewhere that since the power light is blinking and not solid, the dlink in "bricked". I'm not 100% sure what that means but I know it's bad. Anyone know how to fix a bricked dlink? I've looked but found nothing.
Unread 09-02-2011, 21:20
Software Architect
Right, and you've told us that it failed to work multiple times. The question Joe asked was this: have you tried redownloading it? It's possible that the original downloaded file got mangled somehow.
Unread 10-02-2011, 20:58
FRC #3607
yes I did multiple times. We have concluded that the dlink is bricked and are going to get a new one unless someone knows how to fix a bricked dlink. Nothing we have tried seems to work
