Go to Post Girls, if you are techy, great! If you're not, don't worry about it. We're all good at something and FIRST can show you what that is. Just remember, be true to WHO YOU ARE. - Erin Rapacki [more]
Unread 02-09-2011, 08:41 PM
~Cory~'s Avatar
~Cory~ ~Cory~ is offline
Student
AKA: Cory Rypkema
FRC #0706
Rookie Year: 2010
~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold
Working CAN Jaguar [w/ Example Code]
We recently got CAN working on our test platform. I hope we can save all of the c++ teams a bit of time with this:
One Black Jaguar
Code:
#include "WPILib.h" //includes everything
WORKING CAN JAGUAR - CYBERHAWKS 706
Built from simple template
class RobotDemo : public SimpleRobot
	RobotDrive myRobot; // robot drive system, NOT USED
	Joystick stick; // only joystick
	CANJaguar jag;
public:
	RobotDemo(void):
		myRobot(3, 4),	// these must be initialized in the same order
		stick(1),		// as they are declared above.
		jag(1, CANJaguar::kSpeed)
		//jag(1)
		myRobot.SetExpiration(0.1);
	 * Drive left & right motors for 2 seconds then stop, NOT CAN
	void Autonomous(void)
		myRobot.SetSafetyEnabled(false);
		myRobot.Drive(0.5, 0.0); 	// drive forwards half speed
		Wait(2.0); 				//    for 2 seconds
		myRobot.Drive(0.0, 0.0); 	// stop robot
	 * Runs the motors with arcade steering.
	void OperatorControl(void)
//Set up CAN
		myRobot.SetSafetyEnabled(false);//on a dev board
		jag.SetPID(0.4, 0.005, 0.0);//PID
		jag.ConfigEncoderCodesPerRev(200);//This can change
		jag.SetSpeedReference(CANJaguar::kSpeedRef_Encoder);//NEED
		jag.EnableControl();//NEED
		DriverStationLCD *d_st = DriverStationLCD::GetInstance();//DS
		while (IsOperatorControl())
			//myRobot.ArcadeDrive(stick); // simple template
			//jag.Set(20);
			jag.Set(stick.GetY()*150.0);//Set Jag
//The rest is DS output
			//printf("%f\n",stick.GetY());
			//printf("jag temp %f  speed %f  %f   %f  ref=%d\n",jag.GetTemperature(),
			//		jag.GetSpeed(),jag.GetOutputVoltage(),
			//		jag.GetOutputCurrent(), jag.GetSpeedReference());
			d_st->Printf(DriverStationLCD::kUser_Line1,1,"speed = %3.2f   ", jag.GetSpeed());
			d_st->Printf(DriverStationLCD::kUser_Line2,1,"set speed = %3.2f   ", stick.GetY()*150.0);
			d_st->Printf(DriverStationLCD::kUser_Line3,1,"current = %3.2f ", jag.GetOutputCurrent());
			d_st->UpdateLCD();
			Wait(0.005);				// wait for a motor update time
START_ROBOT_CLASS(RobotDemo);
Master/Slave:
Code:
#include "WPILib.h"
 * CAN JAGUAR
 * Uses A master slave setup.  We are using 2CAN controller connected to the bridge.  The master jaguar has an encoder.  The slave does not.  The slave gets output from the master.
	//RobotDrive myRobot; //  drive system
	Joystick rightstick; // right joystick
	Joystick leftstick;// left joystick
	CANJaguar jag1; //Jaguars
	CANJaguar jag2;
public:
	RobotDemo(void):
//old my robot		//myRobot(3, 4),	// Reminants of Simple template
		rightstick(1),		//right stick
		leftstick(2),		//left stick
		//Declare CAN jaguar channels
		jag1(1, CANJaguar::kSpeed),//jag master left
		jag2(2, CANJaguar::kVoltage)//jag slave left
		jag1.SetExpiration(0.1);
		jag2.SetExpiration(0.1);
		//none
		//Jag 1 set up
		jag1.SetSafetyEnabled(false);//This is on a dev board
		jag1.SetPID(0.4, 0.005, 0.0);//PID
		jag1.ConfigEncoderCodesPerRev(200);//Changes per encoder
		jag1.SetSpeedReference(CANJaguar::kSpeedRef_Encoder);//This is on a dev board
		jag1.EnableControl();
		//jag 2 set up
		jag2.SetSafetyEnabled(false);//This is on a dev board
		jag2.EnableControl();
		//DS stuff
			jag1.Set(rightstick.GetY()*150.0);
			jag2.Set(jag1.GetOutputVoltage());
			d_st->Printf(DriverStationLCD::kUser_Line1,1,"speed = %3.2f   ", jag1.GetSpeed());
			d_st->Printf(DriverStationLCD::kUser_Line2,1,"set speed = %3.2f   ", rightstick.GetY()*150.0);
			d_st->Printf(DriverStationLCD::kUser_Line3,1,"current = %3.2f ", jag1.GetOutputCurrent());
			d_st->UpdateLCD();
corin.rypkema.org
WPI Class of '17
'12 Dean's List Finalist, Mentor of 706 - Cyberhawks
