Go to Post The problem with anecdotal evidence is that you never seem to get the whole anecdote. - Lea DeFoote [more]
Unread 10-02-2011, 00:18
Grim Tuesday's Avatar
Grim Tuesday Grim Tuesday is offline
AKA: Simon Bohn
FRC #0639 (Code Red)
Rookie Year: 2010
Grim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond repute
Team 639 Robot
Well, our CAD is finally done. Well, done is a relative term, as now is the time we start drilling first, and cadding later. Anyways, our robot is built to be a solid defender, which puts the minibot first over scoring. We are using treads, and a system to stop ourselves from being pushed sideways (try and see if you can see it in the picture!). The minibots (our fastest clocks in at 3 seconds, but its still getting better) deploy on the tray, which has been timed at .30 seconds to full extension. Our Ladder assembly on the front can reach the top rack, as well as grab from the ground. It cantilevers back into the robot at the beginning of the match, or if we are planning on doing a lot of pushing.
Unread 10-02-2011, 16:51
DarkFlame145 DarkFlame145 is offline
That guy
AKA: Dennis
no team (None this season)
DarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud of
Send a message via AIM to DarkFlame145
Re: Team 639 Robot
looks great!!!!!!
Unread 23-02-2011, 14:56
ipburbank ipburbank is offline
President
FRC #0639 (Code Red Robotics)
Team Role: Leadership
Rookie Year: 2010
ipburbank is an unknown quantity at this point
Re: Team 639 Robot
Updates: Our robot can deploy a minibot, and it climb the pole in a total of 3.5 seconds! With the super-shifters we can easily speed around the field, and plow other bots around. The brakes were removed as they didn't offer much extra except weight.
Aesthetically, CODE RED has been laser cut into some metal, hundreds of CNC holes drilled in the ladder to say 639 on both the top and bottom plates, and red and blue coverings made to match each bumper!
Istvan.
