Go to Post The entire season, when someone yelled "Robot" I would yell back "Human" and stand my ground. - DonRotolo [more]
Unread 10-02-2011, 00:58
Jim Zondag's Avatar
Jim Zondag Jim Zondag is offline
Team Leader
FRC #0033 (Killer Bees)
Rookie Year: 1997
Jim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond repute
pic: In_CIM_erator
Hawiian Cadder's Avatar
Hawiian Cadder Hawiian Cadder is offline
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
Hawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to all
Re: pic: In_CIM_erator
did you look at the specs for those rs775's at 12 volts, at 18 volts they are pretty good, but at 12 volts they produce a measly 70 watts.
Unread 10-02-2011, 00:59
Aren_Hill's Avatar
Aren_Hill Aren_Hill is offline
Build Nifty Things
Aren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond repute
The 12v VERSION at 12v produces the measly 70 watts,
The 18v VERSION at 12v produces much more than that
http://banebots.com/docs/M7-RS775-18-AT12V.pdf
A guy who likes robots.
1625->3928->148->1296->971 oh dear
Unread 10-02-2011, 01:10
Justin Montois's Avatar
Justin Montois Justin Montois is offline
FirstUpdatesNow.com
FRC #3015 (Ranger Robotics)
Team Role: Leadership
Justin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond repute
Send a message via AIM to Justin Montois
lol I'm quite sure they did.
@jmontois340
Team 3015
2016- World Championship Finalists and Tesla Division Champions with 2056, 1690 and 1405
2016- Greater Pittsburgh Regional Chairman's Award
2016- Pittsburgh Regional Finalists with 1023 and 4050
2015- Newton Division Finalists With 195 and 1756
2015- Finger Lakes Regional Champions with 4039 and 378
Unread 10-02-2011, 01:24
AKA: Isaak
Team Role: CAD
pretty sure the 18 volt version is the same, we ran ours and found it MUCH weaker than the RS 550, if anything the 18v version should be weaker than the 12V version, the only difference is the gauge of wire.
Unread 10-02-2011, 01:26
Aren_Hill's Avatar
Build Nifty Things
Any quantitative tests? lifting a load, dynamometer...those spec sheets don't magically appear out of thin air.
Unread 10-02-2011, 01:36
AKA: Isaak
Team Role: CAD
here is the link to the actual source of the motors, BaneBots Buys them from here, and according to this spec sheet
http://www.mabuchi-motor.co.jp/cgi-b..._ID=rs_755vcwc
the "BaneBots rs775 at 12 volts" does somewhere barely above 200 watts at 14.4 volts. the 18 volt version does somewhere around 70.
I am fairly sure that the numbers on BaneBots website are inccorrect, they do match up with a larger motor from this supplier.
http://www.mabuchi-motor.co.jp/cgi-b..._ID=rs_775vcwc
this is the larger motor, but as you can see it is not sold in a 12 volt version, so the 70 watts is close to what this would produce at 12 volts as well, none of the Mabuchi specs come even close to the BaneBots specs.
Unread 10-02-2011, 01:56
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
I think you're confused a bit. Motors are spec'd at a voltage, but will run at any voltage (although, they won't last long once you hit a certain voltage).
A motor rated for 18V will run fine on 12V, it will just be roughly 4/9 the power of it on 18V.
Unread 10-02-2011, 02:00
AKA: Isaak
Team Role: CAD
i am aware, but (4/9) times to 200 watts max power that the supplier has tested for still leaves less than 100 watts of power, unless it is the 14.4 V nominal opperation motor, in which case it will output around 70 watts. according to the people who made the motors, there is no way any of them that size will output more than 100 watts at 12 volts.
also, power is current * Voltage
according to the Bane Bots website peak efficency current is 5.7
5.7 * 12 is 68, which fits the 70 watt power output number, i think all the other info on the BaneBots website is correct, except the power calculation, think that was taken at 18 volts.
Unread 10-02-2011, 02:10
AdamHeard's Avatar
Lead Mentor
The mechanical output power can be calculated from torque times speed.
If you take the motor at half free speed, it is also at half stall torque, for the 775 this works out to over 250W of power.
Unread 10-02-2011, 02:43
rahilm's Avatar
rahilm rahilm is offline
AKA: Rahil Mehta
FRC #0668 (The Apes of Wrath)
Rookie Year: 2007
rahilm has a spectacular aura aboutrahilm has a spectacular aura about
First thing, peak power is NOT peak efficiency. If you look a motor curve, you will find that efficiency is maximized at a much lower current than where power is maximized (at the intersection of the torque and speed lines).
Also, if using the electrical values to calculate output torque, you have to multiple the electrical power value by the motor efficiency at that point.
Team 668 - Apes of Wrath - 2008-2011
Team 668 - Apes of Wrath - 2011-Present (Mentor)
Unread 10-02-2011, 02:54
AKA: Isaak
Team Role: CAD
you are correct, my mistake
i still think it warrants closer inspection however.
Unread 10-02-2011, 03:34
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Rookie Year: 1999
By the way, does anyone have documentation that BaneBots is using that particular RS-775 motor from Mabuchi? (I know there's a part number under the sticker affixed by BaneBots...I just haven't had the opportunity to look underneath and confirm it.) In the past, their motors appeared not to have been Mabuchi-brand.
(And just in case anyone is wondering, yes, this comes up all too often at inspection. Inspectors will often be noticing things like number and shape of vent holes and the colour of the plating on a motor, to quickly assess its legality.)
In fact, the same goes for the other BaneBots motors too. It would be instructive to publish a list of the manufacturers' real part numbers (to forestall future questions about which motor is which).
In 2009, BaneBots shipped totally different RS-550 and RS-385 motors to FIRST teams, despite presumably knowing that there was an FRC parts restriction (given that they were a supplier of KOP motors), and without updating their website to reflect the changes. Given that previous miscue, we probably ought to be cautious.
Unread 10-02-2011, 02:13
John G John G is offline
FRC #0399 (Eagle Robotics)
John G is on a distinguished road
Where did the 4/9 come from. I must have missed something in my math.
  #15   Spotlight this post!
Unread 10-02-2011, 02:17
AdamHeard's Avatar
Lead Mentor
Mechanical power is torque x speed.
Stepping down from 18 to 12V is a 2/3 change.
Power = 2/3Torque x 2/3 speed. Works out to the power at 12V being 4/9 that of 18V.
