Go to Post Goodness, YES. Please get a copy of the rules. It explains a lot, and if your robot does NOT follow the rules, you will not be allowed to compete. Really, it is very important. - DonRotolo [more]
Unread 10-02-2011, 15:10
xinchi.he's Avatar
xinchi.he xinchi.he is offline
AKA: Xinchi He
FRC #1209
Rookie Year: 2011
xinchi.he is an unknown quantity at this point
Send a message via MSN to xinchi.he
Have problem on getting analog values from lane tracking sensor
Hi everyone. I am new here. Here I met with a problem for sensors. My professor would like to use the analog sensor to receive the brightness of the black and white which means I should get values with a range from 0 to 700 whatever. But I couldn't find the method to access it. Anyone could help??
THXX!!!!!!
We are not using the digital sensor that provided by FIRST, instead we use our analog sensor which should plug to the analog side card. Is there a method that in java that could access to the analog value it returns??
