Go to Post Competitions are won or lost far away from witnesses, ... In those long hours, is where we find inspiration in ourselves. For what inspires is not another's feats, but realize we have the power in ourselves to achieve that feat. - Mark Sheridan [more]
Unread 10-02-2011, 15:31
DSST\neal.ian DSST\neal.ian is offline
AAHHH!! WHERE'D ALL THE TIME GO?!?!
AKA: Ian Neal
FRC #2240 (Brute Force)
DSST\neal.ian has a spectacular aura aboutDSST\neal.ian has a spectacular aura aboutDSST\neal.ian has a spectacular aura about
Send a message via AIM to DSST\neal.ian Send a message via MSN to DSST\neal.ian Send a message via Yahoo to DSST\neal.ian
Question Manipulating throttle output (function)
This isn't a question on how to program or anything, but more of a mathematical question (I put it here because I figured this was more oten visited). My question is this: what is a function/equation I can use to change what the lower bound on the throttle is? I know that it gives outputs from -1 to 1 and to use it I need to negate the value that comes out, since "up" is -1. I figured out a function to manipulate the throttle inputs to get values from 0 to 1, which was (Z+1)/2, of course multiplied times -1 to give the right values. Any thoughts, or questions? Did this make sense at all? Thanks.
-2010 Finalists! CO Regional 2010
2240 BRUTE FORCE!!!!!!!
Our site: http://robotics.scienceandtech.org
Unread 10-02-2011, 16:01
AKA: Ian Neal
Re: Manipulating throttle output (function)
To clarify, I want a function in terms of X, Z, an W, where X is the new lower bound, Z is the throttle's raw output (or inverted, it doesn't matter), and W is the new output from X to 1.
Unread 10-02-2011, 16:23
Aaron V Aaron V is offline
FRC #1325 (Inverse Paradox)
Aaron V is an unknown quantity at this point
So as I understand what you're asking: you basically want to scale the range of -1 to 1 to, say, X to 1.
You're totally right in your (Z + 1) / 2 as a start. (The general equation for values not between -1 and 1 is: (Z - oldMinimum) / (oldMaximum - oldMinimum) assuming Z is you value. If you want to know more about why this is, let me know, but I don't think this is your main question). Now what this does is it gives you a value between 0 and 1 (always). Let's call this value P.
Now that you have this, you want to convert it to a new minimum. To get the new equation, you can just rearrange the old one to get: (newMax - newMin) * P + newMin.
So you can combine these things to get a general equation:
(newMax - newMin) * (Z - oldMin) / (oldMax - oldMin) + newMin
Or, you can do them separately if you want.
Unread 10-02-2011, 17:31
AKA: Ian Neal
Sweet! Thanks!
Unread 10-02-2011, 19:45
Originally Posted by DSST\neal.ian View Post
Sweet! Thanks!
No Problem
