Go to Post I would rather Andy Baker be at champs than Will.i.am. - Grim Tuesday [more]
Unread 10-02-2011, 17:26
oceanblack's Avatar
oceanblack oceanblack is offline
FRC #3396 (Imperium Machinamentum)
Rookie Year: 2011
oceanblack is an unknown quantity at this point
Camera Issues With Creating a User
Hi, I'm currently trying to go through the camera setup guide. I am understanding that I first need to create a valid username and then run the Setup Axis Camera VI file.
However, when I connect my camera to my computer via ethernet and set the static IP, I cannot access the webpage. I ping the camera 192.168.0.90 and receive a response - so I know I have a connection.
Anyone know what might be the problem ?
Unread 10-02-2011, 19:37
SuperBK's Avatar
SuperBK SuperBK is offline
AKA: BrianK
FRC #1225 (Amperage Robotics)
SuperBK is just really niceSuperBK is just really niceSuperBK is just really niceSuperBK is just really nice
Re: Camera Issues With Creating a User
Are you using IE? There might be an issue if you are using a different browser. What exactly is the computer set to? put "http://" in the url http://192.168.0.90 in the browser. You might try resetting the camera by holding the reset button when power is turned on.
Brian K
Team 1225 Robotics Mentor
Unread 11-02-2011, 20:45
I've never had a problem with IE or with strict http:// prefixes. My guess is that the computer IP was not in the 192.168.0.xx range for the wired NIC.
Greg McKaskle
