Go to Post Our robot will use sensors to collect information about its environment, then discard that information and drive into a wall. - Jared Russell [more]
Unread 10-02-2011, 18:45
BrynneRaines BrynneRaines is offline
FRC #2224
BrynneRaines is an unknown quantity at this point
Programming an Arm?!?
I've only used Labview for about 7 months and I am still confused. Our team is trying to use a PID to control where the arm starts and stops. For example, only rotating 270 degrees. My problem is that I understand the mechanics of a PID and what it means. I'm just not sure how to even begin building it. I was told to connect a PID to a Motor but what else? How do I even define a program for an arm in the Begin.vi? Some help would be great!
Unread 10-02-2011, 18:58
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Programming an Arm?!?
Here's an example of a motor position slaved to the position of a joystick.
You can replace the joystick with pre-defined values for preset positions.
You do need a sensor on the arm to feedback where it currently is.
Unread 10-02-2011, 21:18
FRC #2224
You do need a sensor on the arm to feedback where it current is.
Thank you! This helped so much.
Unread 11-02-2011, 17:09
FRC #2224
Any other suggestions? Helped but still confused, do I need to make two different programs for the shoulder and forearm. I want the shoulder to move 270 degrees and the forearm 180. How would I do this?
Unread 11-02-2011, 20:47
2829ron 2829ron is offline
FRC #2829
2829ron will become famous soon enough2829ron will become famous soon enough
Have you considered doing a timed function? Motor will only run one way for a set amount of time and then stop. Then run the other way for a set time and stop.
Unread 11-02-2011, 21:56
Triapod Triapod is offline
Triapod is an unknown quantity at this point
I considered this before, but as your battery power decreases, the output you get from your motor also decreases. So even though the time is set, the distance traveled will not be the same. Also the resulting error adds up. I'd go with Mark's idea.
You can do the two motor controls in the same way. Just copy and paste the code you have for one motor: so, have two PID controls, each wired to one of the motors and one of the sensors. The program will be the same, just different device reference and different setpoints.
Unread 13-02-2011, 15:57
lucoytoa's Avatar
lucoytoa lucoytoa is offline
Programmer
AKA: Nicolas Xiong
FRC #2276 (STARS of Cypress)
lucoytoa is an unknown quantity at this point
Do you have an example of this for Labview? We are trying this with our window motor for our claw and I want to open (reverse) for .5 seconds when button 1 is pressed and when 4 is pressed, motor goes forward .5 seconds and stops but still hold the tube securely. Thanks in advance for your help.
FRC - STARS of Cypress, 2008, 2009, 2010
FTC - SOAR Club - 2011
FLL - DNAbots - 2009, 2010
BEST - STARS of Cypress - 2008, 2009, 2010
MATE - STARS of Cypress - 2008
MATE - SOAR Club - 2011
VEX - Discobots - 2010
Robofest - 2008
Houston: Energy City of the Future - RNKL Engineering - 2009
Unread 13-02-2011, 19:41
lucoytoa's Avatar
Programmer
AKA: Nicolas Xiong
I got it to work! Thanks, anyway.
Robofest - 2008
Unread 13-02-2011, 22:14
FRC #2829
Just looked here and saw your question and answer. lol. Yeah I do have an example I could've shared. Tried to program it myself last year, tried it in the pit at competition. Didn't work. Programmer from another team did it for me. FIRST can be nice like that, all the GP in the air
