how do you program with labview to get two motors runing off the same joystick?
Re: labview
For driving, the default Framework comes that way already.
Create a project, Build and Run as startup, test it out. For two non-drive motors, just wire a joystick axis (usually the y-axis) to both Motor Set Outputs. Things can be wired to more than one place. Last edited by Mark McLeod : 10-02-2011 at 19:02. |
