Go to Post Must...squish....bugs... :p - nighterfighter [more]
Unread 10-02-2011, 20:29
bborgen@minot.c bborgen@minot.c is offline
FRC #1101
bborgen@minot.c is an unknown quantity at this point
tetrix allowable parts
Can you use bearings on your mini bot
Unread 10-02-2011, 20:36
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Rookie Year: 1996
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Re: tetrix allowable parts
Look through the approved list on the Team update. Listed are a bronze sleeve bearing and a servo pivot ball bearing.
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
