Deploying Code
Quick Question. We were having some problems. We are using labview, and want to run the code before sending it over wirelessly. We know to connect and ethernet cable from the classmate to the first port on the cRIO. We tried this and had some errors. Do i have to change any internet settings? How do i go about doing this task?
Thanks |
Re: Deploying Code
Go to the KOP website here: http://www.usfirst.org/roboticsprogr....aspx?id=18530
and read the manuals that are posted there. They will take you step-by-step through the process. |
Re: Deploying Code
Re: Deploying Code
Look for the one(s) that would address "some problems" and "some errors" that you're getting. Without getting more detail from you about the trouble, good advice is hard to give.
