Re: Minibot wheel slip
The static friction coefficient was not measured. I just picked a value one can strive toward. You have to use what your design dictates.... maybe more in the neighborhood of .8 if nothing special is done to increase it. So you might need more normal force than I showed. I ran the acceleration test to really determine the magnetic drag. I suspected that it was limiting the magnetic minibots and putting them at a disadvantage. I was unable to detect any significant acceleration that was a function of speed, but the data set was fairly noisy. It would be interesting to see what the distribution of speeds are for the magnetic minibots vs the clamp on's. |
We had a design that had too much friction, and it would do a bizarre "powerhop" maneuver. It is actually pretty neat to see a little 20W robot powerhopping on the pole. We have since gone in a different design direction (well, we have gone in several directions since then, but who is counting). Last edited by IKE : 14-02-2011 at 08:31. Reason: more content |
hey guys, thank you all for the advice you have given me. i switched the gearing around to increase the torque, so i will test it today and see how it works
Just wondering, did you really intend to use a 6" wheel diameter (0.25 ft radius) as your baseline case for this study, or is that a typo? |
From a physics POV, doesn't the formula need a component for the desired acceleration rate up the pole?
"Peeling out" would be reduced by greater normal force. Faster accelerating minibots benefit from greater normal force. There is a balance needed to minimize normal force for gearing friction and maximizing normal force to minimize peeling out in the drag race. Maximizing coefficient of friction is always a good target. |
My simulations have shown that the no_slip condition is not the optimum. After the initial acceleration to steady state speed, the extra drag caused by the high no_slip N causes an unwanted power loss. There is an optimum N that balances the acceleration and steady climb phase ... and for our robots it lies between 1.8 and 2.0 * weight. |
Your choices are 1) increase the normal force and 2) increase the coefficient of friction |
Check: you can increase the normal force with a very ingenuous way using the motors themselves...
