Go to Post I also predict that most predictions will be wrong. - Joe Ross [more]
Unread 11-02-2011, 12:59
Nicholas Norman's Avatar
Nicholas Norman Nicholas Norman is offline
AKA: MrBnC
FRC #0070 (More Martians)
Team Role: Driver
Nicholas Norman is an unknown quantity at this point
Problem with Jaguar Inputs
Okay, so I'm absolutely stumped on this, the code compiles, deploys and the robot can read it but when I try and give it an input with the joystick the robot remains immobile. I've set the Jaguars to use "Set" and the float is the Joystick Y-axis. Here is what I have:
void initMotors()
jMotor[1] = new Jaguar(4,1); // front right
jMotor[2] = new Jaguar(4,2); // front left
jMotor[3] = new Jaguar(4,3); // back right
jMotor[4] = new Jaguar(4,4); // back left
This is in void TeleopPeriodic:
jMotor[1]->Set(m_XboxRightStickY);
jMotor[3]->Set(m_XboxRightStickY);
jMotor[2]->Set(m_XboxLeftStickY);
jMotor[4]->Set(m_XboxLeftStickY);
They Joystick axis floats are set up correctly. So why does this not function properly? Also, this is my first post on Chief Delphi so if I left something out I apologize.
Unread 11-02-2011, 13:05
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
Rookie Year: 2007
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
Re: Problem with Jaguar Inputs
Could we please see your full source code? It's really hard to debug with just a small snippet.
EDIT: I would recommend displaying the joystick values in NetConsole or on the DriverStation to make sure your joystick is functioning properly.
Unread 11-02-2011, 13:08
AKA: MrBnC
Team Role: Driver
Okay, here it is.
BuiltinDefaultCode.cpp
Unread 11-02-2011, 13:10
Zuelu562's Avatar
Zuelu562 Zuelu562 is offline
Ready for WPI District!
AKA: Jake Janssens
FRC #3623 (Terror Bots)
Zuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to beholdZuelu562 is a splendid one to behold
Just going to make sure, it's made me feel like an idiot more than once today;
did you reset your robot after you deployed the code? Also, try undeploying then redeploying.
Team Resume
562 "S.P.A.R.K." - Student Programmer 2008-2011, Field Coach 2011
3623 "Terror Bots" - Technical Mentor, Field Coach 2012 - Present
Volunteer Resume:
BattleCry@WPI 12, 13, 15, 16 - Queuing
BattleCry@WPI 14 - Field Reset
Granite State District Event 2014 - Team Queueing
NEFIRST District Championships '14,'15,'16 - Team Queuing
Unread 11-02-2011, 13:11
AKA: MrBnC
Team Role: Driver
I have multiple times yet every time i get the same result.
Unread 11-02-2011, 13:14
Zuelu562's Avatar
AKA: Jake Janssens
I really have no idea then, I haven't dealt with Xbox control.
Team Resume
Volunteer Resume:
Unread 11-02-2011, 15:25
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
What do the Jaguar's LEDs do while you're moving the joysticks?
Did you remember to ENABLE the robot from the Driver Station?
Unread 11-02-2011, 15:36
AKA: MrBnC
Team Role: Driver
The Jaguar's are blinking yellow as they normally do and yes I did enable the robot.
Unread 11-02-2011, 16:35
Software Architect
Blinking yellow means they're not receiving any commands. You're using PWM control from the Digital Sidecar, right? Make sure your cables are correctly connected to the pins they're supposed to be connected to. The Jaguar PWM connection is obvious, but check to see that you don't have it plugged in backwards. The Sidecar PWM connections are similarly obvious -- they're the widely-spaced triplets of pins with white friction-fit plastic retainers on each set -- but again verify that the connectors are not backwards.
And look at the three power LEDs on the Digital Sidecar. If any of them isn't brightly lit, you need to fix your power wiring.
What is the big orange Robot Signal Light doing while you try to make your Jaguars respond? It should be on with a very brief flicker off about every second and a half.
Unread 11-02-2011, 16:55
AKA: MrBnC
Team Role: Driver
The three LEDs on the Digital Sidecar are brightly lit, and the robot signal light has a short flicker about every two seconds. I don't believe it's a wiring issue. It might be worth mentioning that I'm working on last year's robot until this years is ready to test.
Unread 11-02-2011, 17:02
Software Architect
I hope you updated the cRIO image before you tried using this year's code.
