Go to Post Good drivers know the limits of their machines, but great drivers have machines with no limits. - sanddrag [more]
Unread 11-02-2011, 15:18
sitzikbs sitzikbs is offline
FRC #3316
sitzikbs will become famous soon enough
Gear and motor problem
Hi,
we connected our CIM to a toughbox. it seems that when we try to drive straight ahead it turns to the side.
it also makes noise from one side but we checked the gear and it seems fine.
any ideas about whats causing this and how to fix it?
Unread 11-02-2011, 16:00
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Gear and motor problem
Make sure you didn't assemble one of the gears backwards. There are spacers that keep things from rubbing together the wrong way and making angry sounds.
You know how electrical parts like motors and speed controllers work because of magic smoke? And how if you let the smoke out they stop working? Mechanical parts like gearboxes work because of magic noise. Let too much noise out and they're going to quit.
Unread 11-02-2011, 18:43
sam_who sam_who is offline
FRC #2190
sam_who is an unknown quantity at this point
Check your 2mm key. That's the thing that prevents the gear from rotating on the CIM shaft.
The gear is held on the shaft with the retaining clip. If you don't have one of the retaining clip fingers in the keyway (the slot the key fits in), it's possible for the key to fall out of the slot. Once this happens, the gear does not move with the CIM motor shaft ... at least not as fast as the CIM shaft. Your motor will turn but your tough box output shaft won't.
If one output shaft is turning (assuming right and left motors) but the other isn't, your bot will turn.
