Go to Post Dear CNN, We're not from indiana. Love, Wildstang - AlecMataloni [more]
Unread 02-11-2011, 05:59 PM
Spectare Spectare is offline
Team Hacker
AKA: Benjamin Pylko
FRC #3181 (Pittsford Panthers)
Rookie Year: 2011
Spectare is an unknown quantity at this point
Question CANJaguar current mode
I am on the IgKnighters Team at McQuaid, I am trying to program some small BaneBot DC motors, but I cannot find a way to set the maximum current draw of a CANJaguar so as to not burn out the motor. I can find voltage, but not current. I have tried changeControlMode(CANJaguar.ControlMode.kCurrent), but I am at a loss as for what to do after that. Can Anyone help with this? Thanks in advance!
Unread 02-11-2011, 11:02 PM
drakesword drakesword is offline
AKA: Bryant
FRC #0346 (Robohawks)
drakesword is on a distinguished road
Re: CANJaguar current mode
if you use the current control mode then what you set with the set method is the current outputted to the motor.
for example
Code:
jag.set(10);
Would set the jag to output ~10 amps.
also you can consider the getOutputCurrent() to return the current it is currently outputting
Unread 02-12-2011, 10:42 AM
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
There is no built in way in the jaguar to limit current while using one of the closed loop control methods. However, Ether wrote a white paper called CAN Jaguar Speed or Current Control with Current Limit or Thermal Cutoff which shows an algorithm for doing this on the cRIO.
Unread 02-14-2011, 04:05 PM
Team Hacker
AKA: Benjamin Pylko
Rookie Year: 2011
Thanks, I actually found out that a CANJaguar will not supply more current(or voltage) than is supported by the motor, so . But thanks anyway for the reply.
