Set Speed of Jaguar
Hello guys,
we are trying to run this motor. All the ports are hooked up right. We initiated the Jaguar and did everything but we can't make the motor running. We have a Joystick and if this one button is pressed the motor should start working, but it doesn't. What can we do to fix it? Code:
if(rightstick.GetRawButton(8));
armcrane.Set(1);
Thanks for helping! PS: We are not the best of programmers, so we need a good explaination. |
Re: Set Speed of Jaguar
one way that i coded our arm is this
Code:
if(leftstick.getrawbutton(2)){
vicelbow.set(leftstick.getY())
but then again we are using a xbox controller for our driving and a two joysticks for our arm hope it helps |
What is the Jaguar's LED doing while you try to make the motor run? What is the big orange Robot Signal Light doing? What does the rest of your code look like, specifically the part where you initialize the Jaguar? |
Thanks you guys!
We got the problem fixed now. This thread can be closed. |
Any chance you could tell us what was wrong? Some other team with a similar problem might find the information useful.
