Go to Post Dean Kamen, you deserve a cookie. - Jessica Boucher [more]
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Unread 11-02-2011, 21:58
vinnie's Avatar
vinnie vinnie is offline
FRC #3309 (Friarbots)
Rookie Year: 2010
vinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond reputevinnie has a reputation beyond repute
Waiting to connect to OTA command server
Hi, Netbeans keeps outputting "Waiting to connect to OTA command server of 10.33.9.2:8001 for past xs". Full output of the run process is
Code:
init:
init:
Deleting directory C:\Users\robotics\NetBeansProjects\RobotTemplate\build
clean:
Created dir: C:\Users\robotics\NetBeansProjects\RobotTemplate\build
Compiling 5 source files to C:\Users\robotics\NetBeansProjects\RobotTemplate\build
compile:
Created dir: C:\Users\robotics\NetBeansProjects\RobotTemplate\j2meclasses
preverify:
Created dir: C:\Users\robotics\NetBeansProjects\RobotTemplate\suite
Building jar: C:\Users\robotics\NetBeansProjects\RobotTemplate\suite\RobotTemplate_1.0.0.jar
jar-app:
CompilerOracle: exclude com/sun/squawk/Method.getParameterTypes
CompilerOracle: exclude com/sun/squawk/SymbolParser.getSignatureTypeAt
CompilerOracle: exclude com/sun/squawk/SymbolParser.stripMethods
[translating suite image [closed: false, parent: squawk] ...]
### Excluding compile: com.sun.squawk.Method::getParameterTypes
### Excluding compile: com.sun.squawk.SymbolParser::getSignatureTypeAt
[Including resource: META-INF/MANIFEST.MF]
Romizer processed 89 classes and generated 4 files.
Expanding: C:\Users\robotics\NetBeansProjects\RobotTemplate\suite\RobotTemplate_1.0.0.jar into C:\Users\robotics\NetBeansProjects\RobotTemplate\suite
Moving 1 file to C:\Users\robotics\NetBeansProjects\RobotTemplate\suite
Deleting: C:\Users\robotics\NetBeansProjects\RobotTemplate\image.suite.api
upgrade:
Sending local file image.suite
flashapp:
deploy:
init:
Waiting to connect to OTA command server of 10.33.9.2:8001 for past 11s
Waiting to connect to OTA command server of 10.33.9.2:8001 for past 12s
We are running image v28, after updating to v27, we could not get it to work even after downgrading to v25. Please let me know what I can do to fix this problem. Thanks
Unread 11-02-2011, 22:12
drakesword drakesword is offline
AKA: Bryant
FRC #0346 (Robohawks)
drakesword is on a distinguished road
Re: Waiting to connect to OTA command server
Did you reboot between the imageing and loading the program? we found that to be the issue 9/10 times.
Also make sure your subnet is correctly set to 255.0.0.0
Unread 11-02-2011, 22:59
vinnie's Avatar
Rookie Year: 2010
Subnet is 255.0.0.0, I have reimaged it maybe 10-15 times and rebooted every time and it still doesn't work. Any other ideas?
Unread 11-02-2011, 23:05
AKA: Bryant
How are you deploying code as in how is your laptop hooked to the robot?
The 1/10 mentioned above was that a programmer tried to deploy code via the router over a long distance via wireless to the router.
Unread 12-02-2011, 00:04
vinnie's Avatar
Rookie Year: 2010
I was previously (before v27) able to download code wirelessly, now it doesn't even work downloading over the robot bridge or even hardwired to the cRio.
Unread 12-02-2011, 05:46
michael714's Avatar
michael714 michael714 is offline
FRC #3863 (Pantherbotics)
Team Role: Teacher
Rookie Year: 2007
michael714 is on a distinguished road
If I recall correctly, this could even be a Classmate issue. Reboot the driver station if you haven't already. Also, triple check all IP addresses and all subnet masks. Are you able to ping from developer PC to Classmate, bridge, robot?
When you image, make sure you're using the correct team number. Double check the team number on the Classmate too.
Reboot, reboot, reboot.
Unread 12-02-2011, 08:49
AKA: Bryant
With the checking of the IP make sure you hit the advanced button. Sometimes you will have a listing of multiple IP addresses to use if one is not available.
Unread 12-02-2011, 09:36
eddie12390's Avatar
eddie12390 eddie12390 is offline
AKA: Eddie
FRC #3260 (SHARP)
Rookie Year: 2011
eddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of light
Try sticking something into the Reset place on the cRIO while downloading code.
Unread 12-02-2011, 13:10
derekwhite's Avatar
derekwhite derekwhite is offline
Java Virtual Machine Hacker
no team (FIRST@Oracle)
derekwhite is on a distinguished road
Hey Vinnie,
The output looks a bit curious. It doesn't look like the 2011.6 release at all, but it didn't warn about a cRIO image mismatch either.
Double-check that the netbeans plugin version is 2011.6, and if needed, update them from the WPI update center or download and install from http://firstforge.wpi.edu/sf/projects/wpilib
Unread 12-02-2011, 15:42
12mrsaturns 12mrsaturns is offline
AKA: Awesome
FRC #2029
12mrsaturns is an unknown quantity at this point
This morning I had the same problem, but it started working after I reformatted the cRIO. Don't know why, probably some serious voodoo.
and then, THE END
I know too many programming languages to list.
Unread 12-02-2011, 20:13
dcarr's Avatar
dcarr dcarr is offline
#HoldStrong
AKA: David Carr
dcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond reputedcarr has a reputation beyond repute
We eventually got this working after making sure the CRIO was running version 28 and fully deleting all FRC plugins from netbeans, including the sunspotfrcsdk folder, and then reinstalling the newest plugins.
We did have to manually edit the update.xml file because it was looking for version 27 and we had 28. But after that it worked.
CRIO can be darn frustrating at times =P
The weird thing is that we thought we had fully updated plugins/latest firmware the whole time yet it required a particular sequence of events to make everything work correctly.
Team 3309
2016 Los Angeles Chairman's Award Winner
2016 Orange County Regional Winner with 3476 & 6220
Team3309.org
Orange County Robotics Alliance
