Go to Post and thats my tip of the day. - Tytus Gerrish [more]
Unread 12-02-2011, 10:37
Ian McShane Ian McShane is offline
FRC #3585 (Rogue Robots)
Ian McShane will become famous soon enoughIan McShane will become famous soon enough
How do i change pwm for a specific motor and/or servo in teleop?
in other words, i need to know how to change the port/pwm, in the programming for a specific servo and/or motor vi,
Last edited by Ian McShane : 12-02-2011 at 11:40. Reason: apparently it was originally unclear
Unread 12-02-2011, 10:47
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: How do i change pwm for a specific motor and/or servo in teleop?
I have no idea why you'd want to change the pwm for a specific motor in telop. Are you going to physically move a pwm cable from one position to another in the middle of a match?
If you posted more then "..." and thoroughly described what you wanted to do and why, we might be able to help you. Based on your previous posts, I think you would benefit from reading How to Ask Questions the Smart Way. It takes extra time to compose good questions, but you get answers much faster if people can understand what you're asking, why you're asking it, and what you already tried.
Unread 12-02-2011, 10:54
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Rookie Year: 2007
It looks like you have posted a number of questions here that all boil down to not really knowing how Labview and the provided WPILib VIs work. I highly recommend you forget about the specifics for a minute and try to get a grasp on the basics.
I would recommend you go to this website:
http://www.frcmastery.com/
Watch videos 1-4 under "2011 FRC Steps to Robot Success". Watch video 5 if you get far enough to work on autonomous mode.
Unread 12-02-2011, 10:56
Mtg Ruler Mtg Ruler is offline
FRC #1986 (Team Titanium)
Mtg Ruler is an unknown quantity at this point
For Motors: WPI Robotics Library->Actuators->MotorControl->Set Speed
Speed is [-1,1]
For Servo Angles: WPI Robotics Library->Actuators->Servo->Set Angle
Angle is in degrees
For Servo Position: WPI Robotics Library->Actuators->Servo->Set Position
Angle is [0,1]
You will also need to open a reference for that motor/servo in Begin.vi
To change the PWM, you will need some additional code that will take some kind of input and convert it into pulse (ex. pressing a button sets the motor output to 1)
Unread 12-02-2011, 11:31
Thank you mtg.
