Go to Post It doesn't make a team better if they have just one sponsor or if they have 100 sponsors. However, you should commend a team who struggled to pay the bill with a list of sponsors one hundred long for showing their strength, perseverance and love for participating in the FIRST robotics program. - MikeDubreuil [more]
Unread 12-02-2011, 11:30
Ian McShane Ian McShane is offline
FRC #3585 (Rogue Robots)
Ian McShane will become famous soon enoughIan McShane will become famous soon enough
is the set angle, get angle, or set position the same as set output for motor vi's
if not, which one is?
Unread 12-02-2011, 11:50
Re: is the set angle, get angle, or set position the same as set output for motor vi'
Looking at the diagram, Set Position on a servo ranges between 0 and 1, similar to Set Output for a motor. Set Angle is a wrapper around Set Position that maps the angle between 0 and 1 and calls Set Position. You can use either of them to update a servo to the location you want it.
Greg McKaskle
Unread 12-02-2011, 11:51
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Rookie Year: 2007
None of the above. A motor (for the purposes of this competition) is controlled by setting its speed. A servo is controlled by setting it's angle. It will then move to this angle and hold that position as best it can until you issue a new command.
Mtg Ruler Mtg Ruler is offline
FRC #1986 (Team Titanium)
Mtg Ruler is an unknown quantity at this point
Each VI is different if you open it and look inside
Set Angle sets an angle for the servo in degrees. probably a range of [0,360), but depends on the servo
Get Angle returns the angle that the servo is currently at. probably range of [0,360)
Set Position sets the servo to a percentage of its maximum rotation [0.0,1.0]
These are only for servos, and will likely mess up with motors
Unread 12-02-2011, 12:05
Excellent that was what i needed to know, thanks
