Go to Post "It's not child labor if they wear a team shirt!" - Vermeulen [more]
Unread 12-02-2011, 15:09
joachimbean joachimbean is offline
FRC #3724
joachimbean is an unknown quantity at this point
Typical Minibot Components?
What are the typical components used to build a minibot (and what parts are usually used for the KOP)? I just want to make sure what we're going to use is allowed.
Unread 12-02-2011, 15:11
GaryVoshol's Avatar
Cogito ergo arbitro
Rookie Year: 2000
Re: Typical Minibot Components?
You can only use the materials listed in <R92> for your MINIBOT.
(since 2004)
Unread 12-02-2011, 17:39
FRC #3724
Is there a place to purchase these components? Did any of them come in the KOP?
Unread 12-02-2011, 17:44
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
FTC parts were in FIRST Choice. Otherwise, check the catalog linked to in <R92>. Other than that, you're on your own for those parts, as none of them came in the main KOP. Places to purchase would include a lot of the places that you got other parts from: McMaster Carr, Home Depot/Lows/other similar stores, plastics distributors...
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 12-02-2011, 19:45
FRC #3724
Is there any way to still get a FIRST Choice kit anywhere?
Unread 12-02-2011, 19:56
Chris is me's Avatar
AKA: Pinecone
FIRST Choice ended in mid-January.
Unread 12-02-2011, 19:58
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
Nope, FIRST Choice closed weeks ago and was all out of those when it closed.
However, for FTC parts that are legal, take a look at http://usfirst.org/uploadedFiles/Rob...ix%20Parts.pdf
Then you have to get them from the site for that. (What the site to get those things is, I'm not entirely sure.)
Past teams:
Unread 12-02-2011, 20:32
FRC #3724
Is there any sort of typical bundle of Tetrix parts for a minibot we could purchase?
Unread 13-02-2011, 04:58
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
Check here for more discussion on ordering parts.
When you get to the site mentioned in that thread, you can find the set W731900. Listed at $200 to which you have to add shipping tax etc. That set looks like the hardware supplied in first choice (now expired) option with the exception that it does not include battery, charger, motors, mounts, or switch components. You would have to itemize those items separately to get a workable basis for minibot building.
You could go with the horrendously expensive TETRIX® Education Base Set (W739143) listed at $626. However, that set contains controllers and servos generally thought to be unnecessary for minibots by many posters here on CD. And not as many mechanical bits and pieces as the resource set noted above.
To any order with a motor you should consider the TETRIX® Thermal-Protected DC Motor Power Cable (W736465) to avert the widespread motor failures reported here on CD.
HTH
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
Last edited by Bill_B : 13-02-2011 at 07:11. Reason: FRC discount apparently does not apply to the sets! BOO!
Unread 14-02-2011, 17:09
Glitch_94's Avatar
Glitch_94 Glitch_94 is offline
Mentor
AKA: Harrison Shipp
FRC #3374 (RoboBroncs)
Rookie Year: 2010
Glitch_94 is an unknown quantity at this point
Does anyone know as to whether we can use technic parts from lego, if not these mounts for nxt bricks to tetrix parts are of no use now.
Unread 14-02-2011, 17:13
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
Are any listed in <R92>?
I don't see any either. Therefore, not legal to use LEGO Technic parts.
Past teams:
Unread 19-02-2011, 17:52
cd5696's Avatar
cd5696 cd5696 is offline
&amp;lt;insert something creative here&amp;gt;
FRC #2451 (Pwnage)
Rookie Year: 2010
cd5696 is an unknown quantity at this point
The parts that came in the first choice kit, and many of the legal parts, are part of the Tetrix system. parts for this can be found here
