Go to Post Patents are an issue of law which, alas, has little to do with engineering or common sense. - Mike Betts [more]
  #16   Spotlight this post!
Unread 12-02-2011, 19:40
GaryVoshol's Avatar
Cogito ergo arbitro
Rookie Year: 2000
Re: illegal
Originally Posted by tomy View Post
so any motor is legal as long as we put it on our BOM list
That is not true
my question is what makes a motor illegal
It is legal if it is listed in the manual, rule <R45>. Any others are illegal.
Also you must be in compliance with <R46>, which basically limits the quantities of motors.
(since 2004)
  #17   Spotlight this post!
Unread 12-02-2011, 19:41
ebarker's Avatar
ebarker ebarker is offline
AKA: Ed Barker
FRC #1311 (Kell Robotics)
ebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond reputeebarker has a reputation beyond repute
Re: illegal
<R45> very explicitly explains what motors are legal. If it isn't on this list, then it is illegal.
Going through the history of motors while interesting, isn't helpful. The only thing that counts is <R45>
Ed Barker
  #18   Spotlight this post!
Unread 12-02-2011, 19:45
tomy tomy is offline
FRC #3038 (I.C.E. Robotics)
tomy has a spectacular aura abouttomy has a spectacular aura about
Re: illegal
thanks very much all of you
  #19   Spotlight this post!
Unread 12-02-2011, 19:52
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Re: illegal
The question, as asked, was "What motors used to be legal and are not legal at this time?"
The question that should have been asked is "We have a motor that we would like to use. Is it legal?"
Re: the van door motor: I don't remember a single one in the KOP after 2004. You may be thinking of the Taigene window motor. I couldn't find the VD in the 2006 KOP list, which is on the FIRST site. It certainly wasn't in 2007's KOP. There was none in the 2009 KOP.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
  #20   Spotlight this post!
Unread 12-02-2011, 19:59
Joe G.'s Avatar
Joe G. Joe G. is offline
Taking a few years (mostly) off
AKA: Josepher
no team (Formerly 1687, 5400)
Rookie Year: 2007
Joe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond repute
Send a message via AIM to Joe G.
Re: illegal
A van door motor, or van door-like motor, appeared in the 2008 kit, and disappeared the following year.
FIRST is not about doing what you can with what you know. It is about doing what you thought impossible, with what you were inspired to become.
2007-2010: Student, FRC 1687, Highlander Robotics
2012-2014: Technical Mentor, FRC 1687, Highlander Robotics
2015-2016: Lead Mentor, FRC 5400, Team WARP
2016-???: Volunteer and freelance mentor-for-hire
  #21   Spotlight this post!
Unread 12-02-2011, 20:05
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
Re: illegal
A different Taigene Window Motor, not a van door motor, according to the KOP Checklist for that year. You can see the van door motor under the wheel in http://www.chiefdelphi.com/media/photos/14512
Past teams:
  #22   Spotlight this post!
Unread 12-02-2011, 20:17
ratdude747's Avatar
ratdude747 ratdude747 is offline
Official Scorekeeper
AKA: Larry Bolan
ratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond reputeratdude747 has a reputation beyond repute
Re: illegal
gotcha. the 08 is slightly different. close though.
Dean's List Semi-finalist 2010
1747 Harrison Boiler Robotics 2008-2010, 2783 Engineers of Tomorrow 2011, Event Volunteer 2012-current
DISCLAIMER: Any opinions/comments posted are solely my personal opinion and does not reflect the views/opinions of FIRST, IndianaFIRST, or any other organization.
  #23   Spotlight this post!
Unread 14-02-2011, 15:54
Racer26 Racer26 is offline
Racer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond repute
Re: illegal
All the motors I can remember being in FRC Since 2003:
2.5" CIM Motor (black casing, various p/n's over the years) ?-Present
Keyang Window Motor
Denso Window Motor (not sure on which years which variants were legal)
FP - a few P/N's legal in various years, all with similar, but slightly different specs, 2005-present (i think)
Banebots RS540 2009-present
Banebots RS550 2009-present
Banebots RS775 2011
Banebots RS345 2011
Bosch Drill Motor (silver casing with blue wires attached) ?-2004
Van Door Motor (shaft had a flat on it, looks like a big window motor) ?-2004
3" CIM (bigger than current CIM, and had tensioner thingy) 2005-2006.
Globe Motor (silver motor, with grey gearbox, flat shaft) 2004-2009
I'm probably missing some.
  #24   Spotlight this post!
Unread 14-02-2011, 16:04
thefro526's Avatar
thefro526 thefro526 is offline
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
thefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond repute
Send a message via AIM to thefro526 Send a message via MSN to thefro526
Re: illegal
Originally Posted by big1boom View Post
4 BaneBots motors, any combination of the 4 allowed models.
There are actually 6 legal Banebot motors, The M7-RS775-12, M7-RS775-18, M5-RS550-12, M5-RS550-12-B, M5-RS540-12, and M3-RS395-12.
The two not originally included in the KOP were the RS775-12 (Physically Identical to the RS775-12, but designed to run on 12 volts, less robust and less powerful than an RS775-18 running at 12V) and the RS550-12-B (Functionally and Physically Identical to the RS550-12, but has a longer shaft on back of motor to facilitate encoder mounting.)
You can use any 4 motor combination of the 6 legal motors.
-Dustin Benedict
2005-2012 - Student & Mentor FRC 816
2012-2014 - Technical Mentor, 2014 Drive Coach FRC 341
Current - Mentor FRC 2729, FRC 708
  #25   Spotlight this post!
Unread 14-02-2011, 19:49
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Rookie Year: 1999
Re: illegal
Nobody remembers the Belimo torque motor?
  #26   Spotlight this post!
Unread 14-02-2011, 20:07
Rookie Year: 1999
Re: illegal
Also, there were actually a couple different drill motors. In 2000, 2001 and 2002, there was a Johnson drill motor (roughly RS-775-sized, I believe). Then came the more powerful Bosch/Scintilla drill motor from 2003 to 2004.
There were also several versions of the window motor. In particular, there were both left- and right-hand versions of the Denso, Nippon Denso and a number of externally-similar Keyang window motors. I don't think Tiagene made any, but I could be wrong.
There were several different van door motors, from Bosch and Tiagene (they look like window motors, but are bigger).
  #27   Spotlight this post!
Unread 14-02-2011, 20:34
kevin.li.rit's Avatar
kevin.li.rit kevin.li.rit is offline
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
kevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond repute
Send a message via Yahoo to kevin.li.rit
Re: illegal
We still have that laying around actually.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
  #28   Spotlight this post!
Unread 14-02-2011, 21:36
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Re: illegal
<R45> Motors specifically permitted on 2011 FRC ROBOTS include:
A. all motors, actuators, and servos listed in the 2011 KOP Checklist,
B. an unlimited number of COTS servos with a maximum power rating of 4W ,
C. one or two additional 2½” CIM motors (part #FR801-001, M4-R0062-12, AM802-001A, or PMR25R-45F-1003) in addition to those provided in the KOP. This means that up to four, and no more, 2½” CIM motors can be used on the ROBOT,
D. up to four, in any combination, of the BaneBots motors provided in the KOP (acceptable part numbers are M7-RS775-12, M7-RS775-18, M5-RS550-12, M5-RS550-12-B, M5-RS540-12, and M3-RS395-12)
You should download the KOP Checklist to be sure of what came in the KOP.
Al
WB9UVJ
www.wildstang.org
________________________
  #29   Spotlight this post!
Unread 14-02-2011, 22:14
PAR_WIG1350's Avatar
PAR_WIG1350 PAR_WIG1350 is offline
AKA: Alan Wells
FRC #1350 (Rambots)
PAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond repute
Re: illegal
Mabuchi motor: looks like a BB motor, no gearbox. Don't remember when it disappeared; it was used in 2005.
Various types of Mabuchi motors were in the kit, including 2 versions of the rs-555 in 2010. In 2011, the Banebots motors, which are likely Chinese clones of different Masbuchi motors, replaced them.
this is what the motor looks like
That particular motor is very likely illegal, the gearbox is too small, and the connector should be off-white, not black.
Originally Posted by ratdude747 View Post
no. there are lots of illegal motors. assume a motor illegal until proven legal.
there were also various mabuchi motors (same co. that makes the FP) that were legal last year... but not this year. not sure on when they were KOP.
the window motor above doesn't look legal. the threaded insert was aluminum, not copper. also, the contact covers were white, not black.
I'm fairly sure the FP was, and still is a Johnson Motor, the Mabuchi was made by Mabuchi.
  #30   Spotlight this post!
Unread 15-02-2011, 01:05
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
Re: illegal
It depended on the year. Sometimes, Johnson. Sometimes, Mabuchi. Same specs, different maker (except for 2005, when we all got 6V ones).
Past teams:
