CIM driving 2x faster than others
We just tested driving our bot for the first time since we switched to the new black jaguars. the problem is that one of the cims is driving twice the speed of the other three. we checked all the pwms and made sure that the power was hooked up right. Any Ideas?
Re: CIM driving 2x faster than others
Without seeing any code, may I suggest putting the "bad" CIM onto a jaguar that you know works, and put a "good" one on the jaguar that you think may be faulty? That will tell you if it's the CIM or the Jaguar.
If it's the jaguar, the next step is to use BDC-Comm to set voltage to two different jaguars, the good and the bad, to the same voltage, then use its output to see whether the speed is the same (roughly). If they're not, it's probably the jaguar itself. If it is, it's probably something in the code and you should check your logic carefully. |
Make sure the problem isn't mechanical. Try spinning the gearboxes by hand (backdrive them) and see if the slow one is much harder to spin than the others.
here is our code is there anything wrong there?
Code:
#include "WPILib.h"
#include "Vision/AxisCameraParams.h"
#include "math.h"
#include "CustomMath/CustomMath.h"
#include "C:/WindRiver/workspace/2011_IceRobotics/Xbox360/Xbox360.h"
class RobotDemo : public SimpleRobot
RobotDrive myRobot; // robot drive system
//Joystick leftstick; // left joystick
//Joystick rightstick; // right joystick
Joystick armstick;
HSLImage image; // camera
DigitalInput *left; // digital inputs for line tracking sensors
DigitalInput *middle;
DigitalInput *right;
Victor vicShoulder;
Victor vicElbow;
Victor vicWrist;
Victor vicClaw;
Xbox360 xbox;
DigitalInput *sfsensor; //front sensor
DigitalInput *sbsensor; //back sensor
DigitalInput *efsensor; //front sensor
DigitalInput *ebsensor; //back sensor
DigitalInput *wfsensor; //front sensor
DigitalInput *wbsensor; //back sensor
Gyro gyro;
//ADXL345_I2C acc;
//Encoder En;
public:
RobotDemo(void):
myRobot(1, 2, 3, 4), // these must be initialized in the same order
//leftstick(1), // as they are declared above.
//rightstick(2), // as they are declared above.
armstick(3),
vicShoulder(6),
vicElbow(7),
vicWrist(8),
vicClaw(9),
xbox(1),
gyro(1,1)
//acc(1),
//En()
myRobot.SetExpiration(0.1);
left = new DigitalInput(2);
middle = new DigitalInput(1);
right = new DigitalInput(3);
sfsensor = new DigitalInput(6,1);
sbsensor = new DigitalInput(6,2);
efsensor = new DigitalInput(6,3);
ebsensor = new DigitalInput(6,4);
wfsensor = new DigitalInput(6,5);
wbsensor = new DigitalInput(6,5);
void Autonomous(void)
myRobot.SetSafetyEnabled(false);
//gyro.Reset();
//gyro.GetAngle(); // current heading (0 = target)
AxisCamera &robocam = AxisCamera::GetInstance();
robocam.WriteResolution((AxisCamera::Resolution_t)3);
robocam.WriteBrightness(0);
while(IsAutonomous()){
// read digital inputs
unsigned short leftValue = left->Get() ? 4 : 0; // read the line tracking sensors
unsigned short middleValue = middle->Get() ? 2 : 0;
unsigned short rightValue = right->Get() ? 1 : 0;
//begin Line tracking
switch(leftValue + middleValue + rightValue){
//void MecanumDrive_Cartesian(float x, float rotation, float y, float gyroAngle = 0.0);
case(0x0): // normal operation
case(0x5):
case(0x7):{
//This and 0x0, 0x5, are all the messages recieved if there is no line found
break;
case(0x1): // straif right
case(0x3):{
//0x1, and 0x3 for when the robot sees the line to the right
//Checks to see what the middle value is, and runs until the middle sensor returns true or sees the line
while (middleValue != true){
myRobot.ArcadeDrive(0.0, 0.50);
break;
case(0x2):{
//This is the case for the middle
while (middleValue == true){
myRobot.ArcadeDrive(0.5, 0.0);
break;
case(0x4): // straif left
case(0x6):{
//This case statment if for when it sees the line on the left sensor
myRobot.ArcadeDrive(0.0, -0.5);
break;
default:{
break;
if (leftValue + middleValue + rightValue == 0x0 || 0x5 || 0x7){
//The line has ended and this code is for the arm
Wait(3.0);
void OperatorControl(void)
myRobot.SetSafetyEnabled(true);
gyro.Reset();
Wait(3.0);
while (IsOperatorControl())
//Look for line sensor inputs only when selected
if (xbox.GetRightBumper()){
case(0x5):
case(0x7):{
//printf("no line found \n");
if (!xbox.GetLeftBumper()){
myRobot.MecanumDrive_Cartesian(-xbox.GetRightX(), -xbox.GetLeftX(), -xbox.GetLeftY(), 0); //Mecanum drive at full speed
else{
myRobot.MecanumDrive_Cartesian(-xbox.GetLeftX(), -xbox.GetRightX(), -xbox.GetLeftY(), 0);//Mecanumdrive at half speed
break;
case(0x3):{
// printf("right leftstickX = %f, abs = %i\n",leftstick.GetX(), abs((int)leftstick.GetX()));
float leftvalue = (fabs(xbox.GetLeftX())/-2);
//printf("right leftstickX = %f\n", leftvalue);
myRobot.MecanumDrive_Cartesian(leftvalue, 0, -xbox.GetLeftY(), 0);
break;
case(0x2):{ // keep going
//printf("middle \n");
myRobot.MecanumDrive_Cartesian(0, 0, -xbox.GetLeftY(), 0);
break;
case(0x6):{
//printf("left \n");
float rightvalue = (fabs(xbox.GetLeftX())/2);
//printf("left leftstickX = %f\n", rightvalue);
myRobot.MecanumDrive_Cartesian(rightvalue, 0, -xbox.GetLeftY(), 0);
//myRobot.MecanumDrive_Cartesian(-leftstick.GetX(), -rightstick.GetX(), -leftstick.GetY(), 0);
break;
default:
break;
myRobot.MecanumDrive_Cartesian(xbox.GetLeftX(), xbox.GetRightX(), -xbox.GetLeftY(), 0); //Mecanum drive at full speed
// forward/back
else{
myRobot.MecanumDrive_Cartesian(xbox.GetLeftX()/2, xbox.GetRightY()/2, xbox.GetLeftY()/2, 0);//Mecanumdrive at half speed
//Arm Code
//sf=shoulder front sensor
//sb=shoulder front sensor
//ef=shoulder front sensor
//eb=shoulder front sensor
//wf=shoulder front sensor
//wb=shoulder front sensor
//Shoulder Control
if(((!sfsensor->Get())||(armstick.GetY()<0)) || ((!sbsensor->Get())||(armstick.GetY()>0))) vicShoulder.Set(armstick.GetY()/2); //Shoulder Motor
//Elbow Control
if(armstick.GetRawButton(2)){
if((!efsensor->Get() && !ebsensor->Get())|| //Not either sensor
((efsensor->Get() && (armstick.GetY()<0))|| //on front sensor moveback only
((ebsensor->Get() && (armstick.GetY()>0))))) //on back sensor
vicElbow.Set(armstick.GetY()/2);
//Wrist Control
if(armstick.GetRawButton(3)){
if((!wfsensor->Get() && !wbsensor->Get())|| //Not either sensor
((wfsensor->Get() && (armstick.GetY()<0))|| //on front sensor moveback only
((wbsensor->Get() && (armstick.GetY()>0))))) //on back sensor
vicWrist.Set(armstick.GetY()/2);
//Claw Control
if(armstick.GetTrigger()){
vicClaw.Set(armstick.GetY()/2);
printf("gyro = %f\n", gyro.GetAngle());
Wait(0.005);// wait for a motor update time
START_ROBOT_CLASS(RobotDemo);
anyone?????
Quick glance this looks suspect. For full speed you have '-' in front of xbox.GetLeftY(). And it is positive in the half-speed version.
Code:
// forward/back
else{
the "-" just makes it so it dose not drive backwards and i do not think that would affect the speed of one single jaguar speed controller
Did you forget your machine keys while installing one? That could easily cause an issue while driving.
I'll check tommaorw
