Go to Post In any case, a drawing is important. You should never machine anything without having a drawing of some type to work from. - Big Ideas [more]
Unread 13-02-2011, 11:11
Trevor1743 Trevor1743 is offline
FRC #1743
Trevor1743 is an unknown quantity at this point
Will victor's break mode destroy gear box?
We are planing on having 4 gear boxes each with a Cim and a Bane Bot RS-775 in a CIM-U-LATOR each hooked up to a victor. If we place the victors in breake mode should we be worried that the gears will get destroyed from 1 motor stopping faster then the other?
Unread 13-02-2011, 11:21
JamesCH95's Avatar
JamesCH95 JamesCH95 is offline
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
JamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond repute
Re: Will victor's break mode destroy gear box?
I don't think so, though I assume you're talking about a toughbox or a similar AM transmission.
Are you using an 8-motor drivetrain?
Theory is a nice place, I'd like to go there one day, I hear everything works there.
Maturity is knowing you were an idiot, common sense is trying to not be an idiot, wisdom is knowing that you will still be an idiot.
Unread 13-02-2011, 11:37
FRC #1743
We are using 8 drive motors paired in 2's to go through AM though boxes with a 14.88:1 reduction to drive our mecanum wheels. Acurding to This link we found, we should be able to travel the field in 7 seconds and still be able to push reasonably well for a omni directional robot.
Unread 13-02-2011, 12:11
FRC #1743
Yes and Yes, We are using 8 motors running in pairs each set going into a AM thought box with a 14.88:1 reduction running 8" mecanum wheels.
Unread 13-02-2011, 12:16
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
No. You will not destory the gearboxes.
The brake mode on the Victors shorts the motor wires to ground. Because the wires are connected together, the power generated by moving the motor drives the motor in the other direction, resulting in a braking effect. This is not a very strong force.
Kettering Motorsports
Unread 13-02-2011, 12:27
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
It is a very strong force at high speeds. At rated free speed, the motor braking torque is equal to rated stall torque.
Unread 13-02-2011, 13:14
FRC #1743
So your saying that if we are standing still and a robot with a higher pushing force starts to push us we will push back until they reach a pushing force equal to our maximum pushing force. At which point we will be pushed backwards and our motors will stop working because we would have reached the motor braking torque.
Unread 13-02-2011, 13:33
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
Your motors would have to reach free speed and in that case, you are already being pushed faster than your motors maximum speed.
BRAKE mode won't BREAK your motors, and it won't keep you from being pushed, but it will drive a little bit different, and resisit slight bumps from other robots.
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 13-02-2011, 13:36
Ether's Avatar
Rookie Year: 1969
Sorry, I can't untangle that sentence.
A spinning motor with its leads shorted generates braking torque proportional to its speed. In fact, the braking torque follows the motor's speed-torque curve... with the stall torque and zero swapped, of course: at zero speed there is zero braking torque, and at rated free speed the braking torque is the same as the rated stall torque.
Unread 13-02-2011, 13:49
FRC #1743
Sorry about that.
The order of events which I was trying to express are:
  1. Our robot's sitting still.
  2. Another robot begins to push our robot.
  3. The other robot which is geared to push better then our robot over powers our motors
  4. We get pushed backwords
At this point are our motors broken or not?
Based on Jeffys response:
It does not seem that we will have to fear about our motors breaking.
Thank you for all of the help.
Unread 13-02-2011, 13:53
Ether's Avatar
Rookie Year: 1969
At this point do are our motors broken or not?
If you are being pushed backwards and your wheels are turning then your motors will be braking, but they won't be breaking.
Unread 13-02-2011, 14:36
Hawiian Cadder's Avatar
Hawiian Cadder Hawiian Cadder is offline
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
Hawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to all
my team used essentially the same setup last year, and i can tell you that long before you are going to have any problems with motors the mechanum wheels will skid along the ground. this will not damage your motors at all, and as long as it is driven on carpet it wont damage your wheels either, if you were going to do demonstrations on rough surfaces like asphalt, i would recommend setting the motors to coast to avoid wheel wear. (learned this the hard way, our 8 inch mechs are pretty ruined)
Unread 14-02-2011, 07:18
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Holy overkill batman... I hope you can do all of your manipulation with window motors... how long does your battery last with such a powerful drivetrain?
