Go to Post I walk through the door, and suddenly the field breaks down. It must be my magnetic personality. - Swan217 [more]
Unread 14-02-2011, 18:31
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: 4" Wooden Mecanum Wheel
Originally Posted by TheOtherGuy View Post
The third link you provided gave a ghastly equation (well, a few relatively nice equations with lots of substitution ) on the last page for estimating the parabola, yet when I plot it, the length is off by quite a bit (should go to sqrt(7/2))...
I don't follow you. What are you plotting and what are you comparing it to?
Unread 14-02-2011, 22:03
TheOtherGuy's Avatar
TheOtherGuy TheOtherGuy is offline
Unregistered User
AKA: Kevin Forbes
FRC #4183 (Bit Buckets)
TheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond repute
Sorry, should have elaborated. The blue line is the ellipse I'm currently using for the roller contour, and the purple is the equation found on the last page of the third link. Specifically, the length of the roller L is 2sqrt(7/2)" (from ellipse equation), R is 4", and r is .5". The equations are then:
D = R – r = 4-.5 = 3.5
F = (sqrt(2*3.5^2+(1/2*sqrt(7/2))^2))
G = (sqrt(4*3.5^2+(1/2*sqrt(7/2))^2))
T = (4sqrt(2)/ sqrt(2*3.5^2+(1/2*sqrt(7/2))^2))
A = 32*(2*r-G*(T-1)) / (L^2*(T+1)^2)
But when I plot it, the roots aren't +/- sqrt(7/2). Oh well, maybe I'm just no good at copy-pasting.
Unread 14-02-2011, 23:15
Ether's Avatar
Rookie Year: 1969
Your parabola plot is correct.
The equation simplifies to y= 0.5-0.066683598*x^2
The roots are not supposed to be +/-sqrt(7/2). Why do you think they should be?
If you want the radius to go to zero, you need a longer roller.
Unread 14-02-2011, 23:05
Matt H. Matt H. is offline
Long Distance Mentor
FRC #1726 (N.E.R.D.S.)
Rookie Year: 2007
Matt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond repute
Hey Matt! How's MIT?
Mr. Forbes mentioned those as a first solution, too. It may be worth looking into. I just had a crazy idea that may or may not work, but if it's possible to drill and tap into the end of a #10 threaded rod, maybe I can screw on a small washer onto the ends of the rod.
MIT is challenging, but also fun.
Working from http://www.engineersedge.com/screw_threads_chart.htm, tapping the threaded rods seems as though it will present its own set of difficulties.
Your 10-24 threaded rod has a 0.138" minor diameter (total diameter minus the depth of the threads). This means you will need to use 4-48 or small fasteners to have any material between the inner screw and the outer threaded rod.
Tapping #4 machine screw holes in steel by hand is a pain and repeating the process 48 (or is it 96?) times would likely result in several broken taps/drill bits.
Also, I believe you get into issues with loading on the screws and threaded rod. Speaking qualitatively #4 screws are at risk of breaking during shock loading.
Unread 14-02-2011, 23:06
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
Kevin and I talked on the phone about it, we came up with a few other solutions...like using round, internally threaded, 1/4" od spacers. And a few other ideas.
Good to hear you're keeping challenged, that was always your problem
Unread 14-02-2011, 18:48
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Rookie Year: 2000
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
Originally Posted by squirrel View Post
heh...I used the compound rest. I suggested that the error would be pretty low if we made the half roller as two cones. Kevin figured the angles at 6 and 16 degrees, I set the compound rest to those angles to turn it. then we sanded the lump in the middle to radius it.
Squirrel,
This is how we turn the rollers for our mecanum wheels: http://www.youtube.com/watch?v=1-Zvib5nZVw&hd=1
Manoel Flores da Cunha
Mentor
Brazilian Machine
Team # 383
Unread 14-02-2011, 22:04
MrForbes's Avatar
AKA: Jim
Thank you for posting a link to the video! I thought about using a coarse abrasive if we used rubber rollers, but that would work well with wood too. It makes a mess, but it's an easy way to make the parts.
