Go to Post Help me Chief Delhpi forums, you're my only hope. - Sev [more]
Unread 13-02-2011, 17:28
papii911's Avatar
papii911 papii911 is offline
AKA: Ruddy Mercedes
FRC #0157 (Aztechs 157)
Rookie Year: 2010
papii911 is an unknown quantity at this point
Send a message via AIM to papii911
pic: new design
Unread 13-02-2011, 17:29
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
Re: pic: new design
It's likely you have already heard this, but you should probably put some cross braces between the toughboxes.
Assuming that the baseplate doesn't flex, you will still see alot of flex in the KoP angle brackets and crossbraces will help with that.
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 14-02-2011, 00:24
papii911's Avatar
AKA: Ruddy Mercedes
Rookie Year: 2010
Re: pic: new design
Yes we already had put in the Cross braces for the toughboxes
Unread 13-02-2011, 17:44
Newo95's Avatar
Newo95 Newo95 is offline
AKA: Owen
FRC #0540 (Talon 540)
Team Role: Mechanical
Newo95 is infamous around these partsNewo95 is infamous around these partsNewo95 is infamous around these parts
Re: pic: new design
You should also put something outside the wheels to support the axles and keep unwanted strain off of them and the gears.
--Don't be stupid, it's not smart.
--In conclusion, I conclude that the conclusion was conclusive.
Unread 13-02-2011, 21:14
rutzman rutzman is offline
AKA: Ryan
FRC #2614 (MARS)
rutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant futurerutzman has a brilliant future
Re: pic: new design
We have been using direct-driven, cantilevered mecanum wheels in parades, demonstrations, practices, and Breakaway(with frequent bump crossings) for 2 and a half years with no ill effects.
Just remember that keeping the wheel close to the gearbox will minimize the torque on the shaft.
