Go to Post "We used to shut the robot up in a box and send it away from home. Now we just suffocate it." - GaryVoshol [more]
Unread 14-02-2011, 01:26
Spirator Spirator is offline
AKA: Munaum Muhammad
FRC #3132 (The Thunder Down Under)
Rookie Year: 2010
Spirator is a jewel in the roughSpirator is a jewel in the roughSpirator is a jewel in the rough
Cutting and Fusing Belt
Hello, we're considering cutting and fusing some long gates belt for a conveyor. Have any teams attempted this previously?
Unread 14-02-2011, 03:15
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Re: Cutting and Fusing Belt
I doubt you'll have much luck fusing rubber timing belt. Try urethane belt instead.
Unread 14-02-2011, 20:08
Rookie Year: 2010
Do you have recommendations for tacky roller material?
Unread 14-02-2011, 20:30
AustinSchuh AustinSchuh is online now
FRC #0971 (Spartan Robotics) #254 (The Cheesy Poofs)
Rookie Year: 1999
AustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond repute
Polycord. It was used in all sorts of ball systems in 2009, and on some of the 2007 claws. It's not too hard to fuse together by hand with some heat and patience.
Unread 14-02-2011, 20:47
harryji369's Avatar
harryji369 harryji369 is offline
Captian
AKA: Harry Indrataher
FRC #0369 (High Voltage)
Team Role: Leadership
harryji369 will become famous soon enough
my team is using a belt lock to hold the sides together but it only works if you don`t need the belt to do a full revoloution
