Go to Post Understand that not only can you learn from other experienced engineers, but also mechanics, farmers, and craftsmen. - Andy Baker [more]
Unread 14-02-2011, 08:30
Itamar's Avatar
Itamar Itamar is offline
FRC #1943 (NeatTeam) & FRC #4590 (GreenBlitz)
Rookie Year: 2010
Itamar is an unknown quantity at this point
Which controllers can be used in the competition?
Hey.
I would like to know which controllers can be used in the competition. Can I just buy any controller and make sure it follows a few standarts (if so, what are they?) and if not, is there a list of controllers allowed?
Thank you,
Itamar.
Unread 14-02-2011, 08:35
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Which controllers can be used in the competition?
Please be a little more specific. What do you mean by "controller"?
The cRIO "controller" is the only legal source for commanding actuators.
The Driver Station can use any USB HID joystick or gamepad as a "controller".
Jaguars and Victors are the only legal speed "controllers" identified at present.
Does any of that answer your question?
Unread 14-02-2011, 08:37
flameout flameout is offline
AKA Ryan Van Why
FRC #0957 (SWARM)
flameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to all
What are you referring to?
If you are referring to the robot controller, then no, you must use an FRC cRIO as your robot's controller.
If you're talking about the joysticks, then yes, you can buy any joystick that appears as an HID (Human Interface Device).
I hope this helps.
thefro526's Avatar
thefro526 thefro526 is offline
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
thefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond repute
Send a message via AIM to thefro526 Send a message via MSN to thefro526
What controllers are you referring to?
I'm assuming you're talking about controllers for the Operator Interface, in which case you can use anything that operates over standard USB protocol and is recognized as a game controller, I believe.
Mose teams use Logitech Attack 3 because they're the KOP Joysticks, the Logitech Extreme 3D pro works well if you need a Z-axis (twist) or one of the Logitech Gamepads. There are a bunch of other Joysticks and Gamepads out there too.
-Dustin Benedict
2005-2012 - Student & Mentor FRC 816
2012-2014 - Technical Mentor, 2014 Drive Coach FRC 341
Current - Mentor FRC 2729, FRC 708
Unread 14-02-2011, 12:33
Itamar's Avatar
Rookie Year: 2010
Thank you, and sorry for not being clear, I was talking about a USB joystick.
just to be sure, is there any rule against wireless joysticks?
Unread 14-02-2011, 12:53
Software Architect
<R79> Other than the system provided by the ARENA, no other form of wireless communications shall be used to communicate to, from or within the OPERATOR CONSOLE.
