Go to Post some people sing in the shower........i pretend to be an emcee at championships......:cool: - BanksKid [more]
Unread 14-02-2011, 12:07
qpang qpang is offline
qpang is an unknown quantity at this point
Arcade Drive in Autonomous mode and Tank Drive in Teleop mode?
In Labview, can we keep the Autonomous code as provided, which uses Arcade Drive & 2 motors, but in Teleop mode, use Tank Drive to drive 4 motors?
Unread 14-02-2011, 12:44
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Arcade Drive in Autonomous mode and Tank Drive in Teleop mode?
Simple answer: yes.
The number of motors is actually set in Begin when the drive motors are opened. The default project uses Open 2 Motor Drive. You can replace that with Open 4 Motor Drive.
Once you've done that, any of the drive functions will control it appropriately. Arcade Drive and Tank Drive do exactly what they should. (If you've built a holonomic drivebase with mecanum or angled omniwheels, Holonomic Drive will work too.)
