Go to Post sigh, I started wondering why we weren't there than I realized it was in California. Thats a bit of a road trip... - Raumiester2010 [more]
Unread 14-02-2011, 12:10
pr0ph3t pr0ph3t is offline
Programming and Controls Mentor
AKA: Jeff Ousley
FRC #3528 (Up Next)
Team Role: Coach
Rookie Year: 2011
pr0ph3t is an unknown quantity at this point
mecanum wheels at 45 degrees
I was wondering, does anyone know if it's possible to mount mecanum wheels at 45 degree angles in the corners of the robot (like you would omni wheels) and achieve forward/backward/strafe/spin motions?
Unread 14-02-2011, 12:14
Andrew Schreiber Andrew Schreiber is offline
Data Nerd
FRC #0079
Rookie Year: 2000
Andrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond repute
Re: mecanum wheels at 45 degrees
Possible: Yes.
Useful: No, Mecanums can already achieve those motions as they are (in a very simple sense) omni wheels mounted at a 45 already.
I suggest, if you are still not sure about your drive train that you pull out the KoP frame and put the KoP drive train together since you only have 1 week left.
Unread 14-02-2011, 12:18
Joe G.'s Avatar
Joe G. Joe G. is offline
Taking a few years (mostly) off
AKA: Josepher
no team (Formerly 1687, 5400)
Rookie Year: 2007
Joe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond reputeJoe G. has a reputation beyond repute
Send a message via AIM to Joe G.
Mecanum wheels generate a force at 45 degrees to their axis of rotation. Mounting them at 45 degree angles will add or subtract from this, depending on how you do it, creating either a 0 degree or 90 degree vector. In other words, tank drive! The resultant drivetrain would behave like tank drive, except be harder to build, have low traction, and suffer frictional losses from the mecanum rollers. Not exactly desirable...
FIRST is not about doing what you can with what you know. It is about doing what you thought impossible, with what you were inspired to become.
2007-2010: Student, FRC 1687, Highlander Robotics
2012-2014: Technical Mentor, FRC 1687, Highlander Robotics
2015-2016: Lead Mentor, FRC 5400, Team WARP
2016-???: Volunteer and freelance mentor-for-hire
Unread 14-02-2011, 13:12
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Well, if you swapped the rear left and rear right wheels, and then mounted all 4 wheels at 45 degrees, you'd have a rear-wheel-drive front-wheel-steering vehicle (with lots of frictional losses and poor traction).
Unread 14-02-2011, 13:28
andreboos andreboos is offline
FRC #3021 (The Agency)
Rookie Year: 2010
andreboos is a jewel in the roughandreboos is a jewel in the roughandreboos is a jewel in the roughandreboos is a jewel in the rough
If you have a frame with wheel mounts at 90 degrees to each other (45 degrees from normal), you could use regular omni wheels:
(http://www.andymark.com/ProductDetai...ctCode=am-0013)
Mecanum wheels in that configuration would not be omnidirectional. Rotating the front right and back left wheels 15 degrees counterclockwise and the front left and back right wheels 15 degrees clockwise would provide more power in the forwards direction (I think) while retaining some omnidirectional ability.
Unread 14-02-2011, 13:34
Ether's Avatar
Rookie Year: 1969
If the reference from which you are rotating the wheels in the above is the normal mecanum orientation, then you have the clockwise/counterclockwise swapped.
Unread 15-02-2011, 11:51
AKA: Jeff Ousley
FRC #3528 (Up Next)
Team Role: Coach
Rookie Year: 2011
Thank you, everyone, you've been most helpful.
Unread 15-02-2011, 11:59
Rookie Year: 2010
Oops, I was mixing up my force vectors.
