Go to Post EVERYTHING in life is politics. - Amanda Morrison [more]
Unread 14-02-2011, 15:27
zebrabots zebrabots is offline
FRC #2909
zebrabots is on a distinguished road
minibot string
Can we have a string on our minibot that allows us to pull it down from the top of the pool.
Unread 14-02-2011, 15:28
Matt C's Avatar
Matt C Matt C is offline
FRC #1468 (J-Birds)
Rookie Year: 1999
Matt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond repute
Send a message via AIM to Matt C
Re: minibot string
Does it make your minibot larger than 12"x12"x12"?
Unread 14-02-2011, 15:36
FRC #2909
Re: minibot string
yes, but does it say that the minibot can not exceed playing configurations?
Unread 14-02-2011, 15:41
Nadav Zingerman Nadav Zingerman is offline
FRC #2230
Nadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to beholdNadav Zingerman is a splendid one to behold
Re: minibot string
Yes.
<R91> The MINIBOT may not exceed a 12” x 12” x 12” volume and weigh no more than 15 lbs.
Also, it's not called playing configurations, that refers to the ROBOT.
Unread 14-02-2011, 16:12
FRC #2909
Re: minibot string
Well then how are we suppose to get the minibot off the pole?!?
Unread 14-02-2011, 16:20
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Re: minibot string
That is part of the challenge, Zebra. I guarantee you that you'll see teams who figured out how to build an effective minibot that is also easy and safe to remove.
Unread 14-02-2011, 17:04
joeweber's Avatar
joeweber joeweber is offline
Coach team 1322
FRC #1322 (G.R.A.Y.T. Leviathons)
Team Role: Coach
Rookie Year: 2000
joeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant future
Re: minibot string
Where does it say that the mini bot must start inside the frame parameter at the start of the game?
If your not dirty than you must be just watching.
Thank's to http://weberelectric.biz/
FRC Team sitehttp://team1322.org/
2004 Great Lakes Xerox Creativity Award, 2008 Web Site Excellence Award, 2010 Kettering District and Western Michigan District Excellence in Engineering award, 2011 Kettering District Gracious Professionalism Award. 2011 Ann Arbor and State Cooperation Awards.2013 Kettering Xeroc Creativity Award.2015 Escanaba Chairman's Award.2015 Kettering Spirit Award.2016 Kettering Chairman's Award
FTC Lightining Boltz 5954, Thunder Botz 7032http://team1322.org/vex.htm
Unread 14-02-2011, 17:08
Re: minibot string
<R14> When a ROBOT is in its STARTING CONFIGURATION, no part of the ROBOT shall extend outside the vertical projection of the FRAME PERIMETER (with the exception of minor protrusions such as bolt heads, fastener ends, rivets, etc).
ROBOT – the composite electromechanical assembly designed and built by a FRC team to perform specific tasks when competing in the 2011 competition LOGO MOTION. The ROBOT must include all the basic systems required to be an active participant in the game – power, communications, control, mobility, and actuation. The ROBOT implementation must obviously follow a design approach intended to play the 2011 FRC game (e.g. a box of unassembled parts placed on the FIELD, or a ROBOT designed to play a different game, would not satisfy this definition). The ROBOT includes both the HOSTBOT and one MINIBOT (ROBOT = HOSTBOT + MINIBOT).
FRAME PERIMETER – the polygon defined by the outer-most set of exterior vertices on the HOSTBOT (without the BUMPERS attached) that are within the BUMPER ZONE.
Taken together, you can see that all parts of the ROBOT (which, by definition, contain both the HOSTBOT and the MINIBOT) must reside within the FRAME PERIMETER at the start of the match.
