Go to Post Don't forget to stock up on luck. You'll need some of that too. - Molten [more]
Unread 14-02-2011, 16:04
zahayaa zahayaa is offline
FRC #0714
zahayaa is an unknown quantity at this point
signals
can we put signals in the robot for the 2011 game
Unread 14-02-2011, 16:13
thefro526's Avatar
thefro526 thefro526 is offline
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
thefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond repute
Send a message via AIM to thefro526 Send a message via MSN to thefro526
Re: signals
What do you mean by signals?
Turn Signals?
Position Signal lights?
Hands to Hand Signal with?
-Dustin Benedict
2005-2012 - Student & Mentor FRC 816
2012-2014 - Technical Mentor, 2014 Drive Coach FRC 341
Current - Mentor FRC 2729, FRC 708
Unread 14-02-2011, 16:22
FRC #0714
Re: signals
signals that could tell the human player what tube to put out.
Unread 14-02-2011, 16:28
thefro526's Avatar
Mentor for Hire.
Re: signals
Assuming that no other rules are broken in the process, then it's perfectly legal to build and use a Human Player Signalling device on your robot. Our team is using an array of LEDs and so are many others.
-Dustin Benedict
Unread 24-02-2011, 20:20
Jim Wilks Jim Wilks is online now
Electrical Engineer
AKA: Jim Wilks
FRC #1360 (Orbit Robotics)
Jim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond repute
Re: signals
I gather that a spike relay must be used to interface each signal light. That would be 3 spikes to cover the 3 logos.
Any other options?
Unread 24-02-2011, 20:23
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
BrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond repute
Re: signals
Any other options?
Program one spike to control two LEDs which would mean you need two spikes.
1519 Mechanical M.A.Y.H.E.M. 2008 - 2010
3467 Windham Windup 2011 - 2015
1058 PVC Pirates 2016 - xxxx
Unread 24-02-2011, 22:29
kevin.li.rit's Avatar
kevin.li.rit kevin.li.rit is offline
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
kevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond reputekevin.li.rit has a reputation beyond repute
Send a message via Yahoo to kevin.li.rit
Re: signals
Or control 3 LEDS with 1 spike. granted you could not have all the on off states of the LEDS.
I also believe you are able to use the Digital and analog outputs for this purpose
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 24-02-2011, 22:47
AKA: Brendan Browne
Re: signals
Ooooh getting smancy!
Unread 25-02-2011, 09:31
Matt C's Avatar
Matt C Matt C is offline
FRC #1468 (J-Birds)
Rookie Year: 1999
Matt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond repute
Send a message via AIM to Matt C
Re: signals
http://www.chiefdelphi.com/media/photos/36358
A "simple" idea using some 12v bulbs, a cheap flashlight housing and reflector, and a servo with some lexan attached to it. One could also just make some non-powered "flags" and attach them to the servo as well, have em poke through your bodywork or whatnot.
Unread 25-02-2011, 13:10
MattC9's Avatar
MattC9 MattC9 is offline
MattC9 has a spectacular aura aboutMattC9 has a spectacular aura aboutMattC9 has a spectacular aura about
Re: signals
Were making led boards and putting pwm's on them and plugging them in to a digi sidecar
Unread 25-02-2011, 13:45
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Rookie Year: 2007
Re: signals
Another option is this handy signalling light from AndyMark available 3/4
http://www.andymark.com/ProductDetai...ctCode=am-0897
It uses a spike relay to control the LEDs
The views expressed are mine and should not be construed to represent the views of anyone else.
