Go to Post anything that breaks a kitbot frame is probably breaking most custom frames of similar weight, too. - dtengineering [more]
Unread 14-02-2011, 18:00
zransom515 zransom515 is offline
AKA: MSU bound programmer
FRC #2420 (RoboTitans)
zransom515 is an unknown quantity at this point
Smile How to program motors in two different directions.?
So I have been on my FRC team for four years. This is my first year actually programming. In previous years I have helped with awards and public relations. We have an arm for the FRC 2011 LOGOMOTION. I have programmed for the basic drive. I am having a problem programming the motors, so that when a button is pressed it spins one way and when another button is pressed it spins another. How do I go about doing that?
Unread 14-02-2011, 18:56
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: How to program motors in two different directions.?
See attached image.
Name:	fwd or rev.png
Unread 14-02-2011, 23:43
baronep's Avatar
baronep baronep is offline
Student President
FRC #2848 (Jesuit All-Sparks)
Team Role: Leadership
Rookie Year: 2010
baronep is on a distinguished road
You could also use two case structures, one inside the other, each controlled by a button on your controller. The only trick is that there is one case where both buttons are pressed. In that case you could either have the motor stop or continue in one of the two directions, but practically speaking, this isn't a big deal.
