Go to Post So my mom gave up most of the house to robotics.... - ElfMaster [more]
Unread 14-02-2011, 18:21
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
how to model motor+gearbox
What is the accepted wisdom here on CD of the "correct" way to model a motor plus gearbox combination[1]?
More specifically, if I have
- a motor with given free current, free speed, stall current, and stall speed, and
- a gearbox with given gear ratio and "efficiency"
... and I combine them together,
then what is the free current, free speed, stall current, and stall speed of that combination?
For example, suppose I bolt a CIM to a gearbox that has ratio 10:1 and efficiency 90%. Then:
- the free speed at the gearbox shaft should be slightly slower than 1/10th of the CIM's free speed, because of the friction in the gearbox... but how much slower?
- the free current should be slightly more than the CIM's free current (because of the torque load of the gearbox friction), but how much more?
- the stall current should be exactly the same as the CIM stall current
- the stall torque would be less than 10 times the CIM's stall torque, but how much less?
- assume a linear behavior between free and stall points?
Endnotes:
1] I'm talking about a simple model for hand calculations for FRC purposes, not a complex simulation.
