Go to Post Our job as mentors isn't to teach them how to make a robot...It's to teach them that there is value in technology and being among the people who create it. - Andy A. [more]
Unread 14-02-2011, 20:52
bscharles's Avatar
bscharles bscharles is online now
Booyah
AKA: Brian Scharles
FRC #0930 (The Mukwonago BEARs)
Rookie Year: 2010
bscharles will become famous soon enough
Labview to Dashboard Communication
We are using Labview to program our robot this year. I am trying to get our crio to send data back to our dashboard. When running a brand new crio project, it sends back the data (analog inputs, pwm, etc.) correctly. However, when trying to get it to send back information from the project we have been using for the entire season, it sends back data when i first connect the laptop to robot. Yet, when i enable the robot, it stops communicating. We are heavily relying on the dashboard for our drivers this year.
Unread 14-02-2011, 23:46
baronep's Avatar
baronep baronep is offline
Student President
FRC #2848 (Jesuit All-Sparks)
Team Role: Leadership
Rookie Year: 2010
baronep is on a distinguished road
Re: Labview to Dashboard Communication
Make sure that your dashboard laptop has all of the required updates and make sure that you have re-imaged your cRio since the kickoff, it should be v27. If you don't see v27, then you have yet to install the latest labview updates which can be accessed on the Labview splashscreen
Unread 15-02-2011, 16:15
bscharles's Avatar
Booyah
AKA: Brian Scharles
Rookie Year: 2010
I know that the crio we are using has the latest image (v27), and I am almost positive i updated the laptop we use for programming to the latest labview version (3.1), but i will check again tonight
Unread 15-02-2011, 17:48
Dave Scheck's Avatar
Dave Scheck Dave Scheck is offline
FRC #0111 (WildStang)
Dave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond repute
When you say it stops communicating, do you just mean that the dashboard data doesn't get updated? Is it possible that you're not sending updated data from the robot when enabled? If you disable the robot does the data come back?
Unread 15-02-2011, 22:43
bscharles's Avatar
Booyah
AKA: Brian Scharles
Rookie Year: 2010
Thank you for your responses. I finally got it to work by using the send user data high command in the teleop vi. Not sure if this is the only way, but it works now, and thats all that matters
