Go to Post Sally Ride says role models are needed - that's you. - JaneYoung [more]
Unread 14-02-2011, 21:00
Mandelbrot's Avatar
Mandelbrot Mandelbrot is offline
FRC #3007 (ROBOTITANS)
Mandelbrot is an unknown quantity at this point
Changing a joystick name?
Has anyone else had problems with knowing what joystick is stick 1 or stick 2? We have three joysticks and two of them show up as "Attack 3" We are testing our arm out so I really want to know what's going to happen before I touch a joystick moving something that big. I thought about re-naming the sticks somehow so that they are easier to sort. Does anyone know how to do this, or an even better way?
Humans are like slinkies. Practically useless, but still fun to push down stairs.
Unread 14-02-2011, 21:12
MagiChau's Avatar
MagiChau MagiChau is offline
AKA: Michael Chau
FRC #0085 (B.O.B. (Built on Brains))
Rookie Year: 2010
MagiChau is just really niceMagiChau is just really niceMagiChau is just really niceMagiChau is just really nice
Re: Changing a joystick name?
I would reccommend you applying some tape onto the joysticks and their USB connector so you can easily identify them physically. You can name an object almost anything in programming. I use leftStick, rightStick, and auxStick (auxilliary.)
Unread 14-02-2011, 21:25
rwood359 rwood359 is offline
AKA: Randy
FRC #0359 (Hawaiian Kids)
rwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to all
In the Drivers Station Setup screen, with the robot disabled, pull the trigger on a joystick. You will see an indication of which joystick is being used. You can drag the joysticks up or down to get the physical joystick associated with the logical address that you want.
Unread 15-02-2011, 10:10
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
The game controller name comes hardcoded from the firmware in the joystick device. The name is not editable in the Driver Station application.
The only easy way I've found to uniquely identify a joystick (aside from pushing a button and watching it flash on the Setup tab), so far has been to combine different models.
E.g., Attack3, Extreme Pro, MadCatz
