Go to Post A good driver will always win over a good robot. - Mike Norton [more]
Go Back   Chief Delphi > Technical > IT / Communications > 3D Animation and Competition
Unread 15-02-2011, 10:20
Kevin Thorp's Avatar
Kevin Thorp Kevin Thorp is offline
AKA: Kevin Thorp
FRC #3489 (Category 5)
Rookie Year: 1998
Kevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond repute
Help - WMV to MOV converter?
A mentor on another team said her students saved their edited video in Windows Media (.WMV) format. They found a free .WMV to .MOV converter but it leaves a watermark on the video.
Any suggestions to help them convert it to Quicktime?
Unread 15-02-2011, 10:32
TomT_1517's Avatar
TomT_1517 TomT_1517 is offline
Animation Mentor
AKA: Tom Tosi
FRC #1517 (Lumberjacks)
Rookie Year: 2011
TomT_1517 is an unknown quantity at this point
Re: Help - WMV to MOV converter?
Hi,
Try Video Pad. There is a free "lite" version and there is a paid version. I think the free version does what you need. I can't be positive because a year or so ago I upgraded to the pay version and can't remember which features were restricted in the free, but I think it will do it for you. I know of other fee-based tools, but if you want to try the free first...
Team 1517 Lumberjacks participating in Granite State Regional and Festival de Robotique FRC a Montreal
Regional in 2012. Hope to see you all there!
Unread 15-02-2011, 10:35
TomT_1517's Avatar
Animation Mentor
AKA: Tom Tosi
Rookie Year: 2011
Originally Posted by TomT_1517 View Post
Hi,
I should also mention that it would be better if you encoded to mov straight from your edit rather than going through a wmv first, but I do realize that it is very late in the game today and you may be in a situation where you have to do what you have to do. Best of luck!
Unread 15-02-2011, 11:09
HansJ's Avatar
HansJ HansJ is offline
AKA: Hans
FRC #3018 (Nordic Storm)
Team Role: Mechanical
Rookie Year: 2010
HansJ is on a distinguished road
I like to use Any Video Converter Free. The only gripe I have is that there is a popup about upgrading to the paid edition after converting. Minor problem.
2013 Lake Superior Excellence In Engineering Winner
2013 Lake Superior Dean's List Finalist
2013 10,000 Lakes Engineering Inspiration Winner
2013 Championship Creativity Award Winner
Unread 15-02-2011, 11:30
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
I personally like Handbrake for video conversions. I've had to do a few format conversions for various websites I've managed (including a fairly big job last year of converting a friends website to be compatible with mobile devices), and found that it's by far the easiest to use. I've only used it on Macs, but it's available for Windows, Ubuntu, and Fedora as well.
Unread 15-02-2011, 11:50
Chris is me's Avatar
AKA: Pinecone
Each time you convert a video to another lossy format, the quality drops. Do everything you can to keep videos in one format.
ffmpeg or some derivative (VLC) is probably your best bet.
Unread 15-02-2011, 12:29
TD912 TD912 is offline
AKA: Chris Leung
FRC #1989 (Viking Robotics)
TD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud ofTD912 has much to be proud of
Every time you convert to another lossy format, you lessen the quality.
Think of it as taking a photocopy of a photocopy of a photocopy, etc. It gets worse each time. Plus many half-baked programs are not very efficient when converting. It's one of the reasons why so many amateur videos on YouTube look blurry. If possible, exporting directly to a .mov would be best.
If you can't, set the bitrate for the .wmv relatively high, around 1500kbps for SD content. When you convert to a .mov, set it also around 1500kbps and make sure the video codec is set to H264. This way more of the information is retained. The higher the better, but the larger the file and the longer it takes to encode. There is a lot more to encoding video than that, but those are just some general guidelines.
If it weren't for the submission rules, I would have suggested using Handbrake, as it is relatively easy to use, outputs high quality files using the well-known x264 encoder, and is free. But Handbrake does not output to a .mov file.
I'm not sure why a .mov file is specifically required by FIRST/Autodesk, as the .mov container is slowly being depreciated by Apple in favor of .mp4, which is the standard container for H.264 and AAC audio, which is used in everything from iPods to Blu-ray players. Even standard YouTube video is streamed in H.264 inside a Flash player.
Zip-ties, hot glue, and duct tape.
2008 New York City Regional Champions - (41/555/1989)
2009 Brunswick Eruption 8 Finalists - (1989/56/1807)
2010 PARC XIII Champions - (25/341/1989)
Over The Bump
Unread 15-02-2011, 13:08
Chris27's Avatar
Chris27 Chris27 is offline
AKA: Chris Freeman
FRC #1625 (Winnovation)
Chris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant futureChris27 has a brilliant future
Just to be clear, a video container (e.g. mov, wmv, avi) is not the same as an encoding format (e.g. XVID, x264). You technically don't have to reencode the video when you extract the video source from one container and put it in another. It is perfectly valid to take, say an x264 video, from a container such as a .mov and place it in another container such as a .mp4. Since the video is not encoded (compressed) again, there is no quality loss.
Typically, different video and audio codecs are associated with different containers. If you choose a bizarre codec container combination, your video player may not correctly handle the file. You typically don't have to worry about this as most video encoding software will choose the codecs for you when you select the container type.
I can also vouch for handbrake (or at least the mac version)
Unread 15-02-2011, 13:26
AKA: Pinecone
While the above is true, you can't contain many encoding formats wmv uses in mov containers
Unread 15-02-2011, 13:42
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Format Factory
