Go to Post If duct tape isn't the answer, you're not asking the right question. - Morgoth [more]
Unread 15-02-2011, 12:02
pcfens pcfens is offline
FRC #1137
pcfens is an unknown quantity at this point
Compressor Issue
We've recently had a strange issue develop with our compressor system that I can't seem to figure out.
We have the pressure switch wired with the signal (white) wire to one terminal and ground (black) to the other. In code, we instantiate and start the compressor object, and the compressor correctly starts.
When the pressure switch opens, the compressor stops, however we also loose all communication with the robot.
I'm the programming mentor and haven't seen the behavior for myself yet, but I'm interested to know if you can think of any mistake that could be causing this. (Spike relay wired backwards?)
Thanks.
Unread 15-02-2011, 22:33
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Compressor Issue
Absolute pure speculation here, but are the cRio, compressor and spike all isolated from the chassis? Sounds like some back EMF from the (inductive) compressor motor shutting off is getting into somewhere it shouldn't.
Unread 18-02-2011, 08:41
Rion Atkinson's Avatar
Rion Atkinson Rion Atkinson is offline
The CAD Guy
Rion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond reputeRion Atkinson has a reputation beyond repute
Not sure if this has been solved yet, but speaking from experience, check the battery.
‎‎"I know not with what weapons World War III will be fought, but World War IV will be fought with sticks and stones. -Albert Einstein
Start Something
Email - rionatkinson@gmail.com
Skype - Rion.Atkinson
