Go to Post My crotchety old person opinion is that it should be illegal to try to win the award. Do things because you like doing them or because it helps others. Don't do things to win awards. - Madison [more]
Unread 15-02-2011, 15:56
cilginbilgin cilginbilgin is offline
FRC #2905
cilginbilgin is a jewel in the roughcilginbilgin is a jewel in the roughcilginbilgin is a jewel in the roughcilginbilgin is a jewel in the rough
Exclamation Watchdog Not Fed
This is my code and driver station says Wathdog Not Fed when I run this code.
Here is my code if someone can tell me what to do I would be pleased.
Thanks in advance!!!
Uploaded with ImageShack.us
Unread 15-02-2011, 16:25
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Watchdog Not Fed
There's something very strange about that code. You're apparently trying to read photosensor outputs using Solenoid Get? That won't work. The photosensor signals should go to Digital I/O pins on the Digital Sidecar, and you should read them using a DIO Get.
Unread 15-02-2011, 16:27
FRC #2905
Originally Posted by Alan Anderson View Post
What have you changed from the original Autonomous Independent?
Are the IR1, IR2 and IR3 digital inputs being opened in the Begin vi?
I have changed Digital Input to Solenoid because we wired our photosensor to Solenoid Breakout! But Is that for sure that our Watchdog will work. I think I have made some mistakes about Watchdog in Autonomous Independent.vi
Also I have added watchdog get reference and wired it to Watchdod Feed in Autonomous Independent.vi.
Unread 15-02-2011, 16:35
FRC #2905
http://www.chiefdelphi.com/forums/sh... +photosensor
Here it says we can wire photosensor to Solenoid Breakout!
Unread 16-02-2011, 09:34
Software Architect
You can wire the photosensor power wires (brown to plus, blue to common) to the output of a Solenoid Breakout connected to the 24 volt cRIO supply. If you do that, you will have to turn the solenoid output on in order to power the sensor.
The photosensor signal wires (black or white) still need to be read using a Digital Input.
Unread 16-02-2011, 10:58
FRC #2905
Question Re: Watchdog Not Fed
I was wondering will my watchdog code work?
