Go to Post Bottom line: I would suggest that you walk a mile in our shoes and volunteer to be an inspector at your next event... - Mike Betts [more]
Unread 15-02-2011, 17:05
DarKCroNo's Avatar
DarKCroNo DarKCroNo is offline
FRC #2670
DarKCroNo is an unknown quantity at this point
Analog Module?
Our team was wondering if we are able to plug the analog module in any other slots, as the only space for the crio on our robot needs all the modules hanging around the back of the Crio (using slots 4-8). When we take a look at the driver station javadoc, it has a final value for the analog break out at slot 1.
All we use our analog module is for the battery voltage, if it is not possible to change the slot we are also wondering if it is required during the match
