Autonomous Problem saving power values
When opening the Autonomous vi front panel by default all the values are negative. I change them to positive values and run the program on the robot and it works flawlessly. Then I attempt to save it, but it always goes back to the negative. How do you change and save those values?
Re: Autonomous Problem saving power values
To save all the front panel values, click "Edit -> Make Current Values Default"
To save only one of the front panel values, right click on it and go "Data Operations -> Make Current Value Default" |
Thank you!!
