Go to Post It's amazing what you'll find in the FIRST Manual :) - dcarr [more]
Unread 15-02-2011, 20:13
biancs15's Avatar
biancs15 biancs15 is offline
Driver, Design and Manufacturing
AKA: Austin
FRC #0610 (Coyotes)
Team Role: Leadership
biancs15 is a splendid one to beholdbiancs15 is a splendid one to beholdbiancs15 is a splendid one to beholdbiancs15 is a splendid one to beholdbiancs15 is a splendid one to beholdbiancs15 is a splendid one to beholdbiancs15 is a splendid one to behold
Replacement for Vex treads
Hello Everyone,
This year, with team 610, we are using vex treads on our manipulator.
However the problem is that sometimes when we handle the tubes, the tread breaks.
I was just inquiring if any of you know a company that sells solid / sturdy tread (with links) made from plastic or metal?
Thank you all very much.
Sincerely,
Austin
2013 Team Co-Captain, Base driver, Head of Design and Manufacturing
2013 Waterloo Regional Finalists
2013 BAE Systems Regional Winners
2012 Arizona Regional Winners
2012 GTR East Regional Finalists
2011 Galileo Division Finalists
2011 Waterloo Regional Finalists
2011 GTR West Regional Finalists
"When in Rome"
Unread 15-02-2011, 21:04
artdutra04's Avatar
artdutra04 artdutra04 is offline
VEX Robotics Engineer
AKA: Arthur Dutra IV; NERD #18
FRC #0148 (Robowranglers)
artdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond repute
Re: Replacement for Vex treads
Try using 35-pitch roller chain attachment links to make your own "tank tread", much like this:
http://www.chiefdelphi.com/media/photos/25846
Art Dutra IV
Robotics Engineer, VEX Robotics, Inc., a subsidiary of Innovation First International (IFI)
Robowranglers Team 148 | GUS Robotics Team 228 (Alumni) | Rho Beta Epsilon (Alumni) | @arthurdutra
世上无难事,只怕有心人.
Unread 15-02-2011, 21:07
Chris is me's Avatar
AKA: Pinecone
How does the tread break and where?
The load strength of the link is over 30 pounds if I remember correctly. Maybe there is too much tension (!) in your system.
Unread 16-02-2011, 11:14
biancs15's Avatar
AKA: Austin
FRC #0610 (Coyotes)
Thank you both very much for your ideas and input.
Good luck at the competitions!
"When in Rome"
Unread 17-02-2011, 12:47
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Rookie Year: 1996
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Smile Re: Replacement for Vex treads
In addition, check to make sure your gears or drive sprockets do not have excessive runout. That can cause excessive tightening of the chain or belt which might not be obvious unless you run the drive manually and check tension periodically as you do this.
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
