Go to Post But when it comes down to it, the best teams usually end up winning regardless. - Cory [more]
Thread Tools Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
Unread 15-02-2011, 23:13
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
kamocat is just really nicekamocat is just really nicekamocat is just really nicekamocat is just really nicekamocat is just really nice
Send a message via AIM to kamocat Send a message via MSN to kamocat
NI Vision assistant: Acquire Axis image
I'm having trouble with the "acquire image from Axis" feature.
When I try to "acquire a single image" or "acquire continuous images", I get the error:
Sequence acquisition returns no errors, but all the images come out black.
I can use the WPI Camera Vis to acquire images with LabVIEW with the default IP address: 192.168.0.90. (This is the IP address used in the NI Vision Assistant as well).
Am I doing anything wrong?
(There are plenty of workarounds, but it'd be nice if this feature worked)
-- Marshal Horn
Unread 16-02-2011, 20:03
Re: NI Vision assistant: Acquire Axis image
Are you talking about the Acquire Image (Axis IP) camera type? Then you press play or get single image?
I wouldn't expect that error, but if it doesn't work for a given camera, check the account setup on the camera. Also, occasionally the cameras will return a server busy error, but again, I wouldn't expect that to turn into a zero length image data error.
Greg McKaskle
Unread 16-02-2011, 22:04
kamocat's Avatar
Test Engineer
AKA: Marshal Horn
You were right about the configuration.
It appears the NI Vision Assistant only uses the FRC, FRC username/password combination, wheras the WPI code will work with any of three combinations.
-- Marshal Horn
