Go to Post There is a really bad trap most people fall into, when presented with data they tend to trust it. This is dangerous. - Andrew Schreiber [more]
Unread 16-02-2011, 00:25
David El David El is offline
FRC #2625
David El is an unknown quantity at this point
Downloading Code Predominantly
Alright so we can deploy the code and run the robot and everything however we can not get the code to stay on the robot after we restart the machine. We are currently downloading it onto the ram and we are aware that thats not the way to make it stay but we can not figure out the other way in order to have it saved on there. We researched a bit and found that we have to press download in win river, however it asks for a "ELF file?" and we have no such file with that extension in our entire project.
Help would be much appreciated,
David from team 2625
Unread 16-02-2011, 08:47
jwakeman jwakeman is offline
FRC #0063 (Red Barons)
Rookie Year: 2010
jwakeman is just really nicejwakeman is just really nicejwakeman is just really nicejwakeman is just really nicejwakeman is just really nice
Re: Downloading Code Predominantly
It looks like these folks, http://www.chiefdelphi.com/forums/sh...ad.php?t=91896, are having a similar issue. To deploy the code you should go to Window->Preferences->FIRST Downloader Preferences. Set you team number and browse for the .out file that is created when you compile your project. When that is done goto FIRST->Deploy. Reboot your cRIO and it should be running your program.
An ELF file is any executable file in a unix/linux type OS such as vxWorks. Also there is no concept of a file extension in these types of OS's. File extensions only exist in Windows (and maybe Macs, not sure). So that means the .out file from your project is an ELF file. Hope that helps, good luck!
Unread 16-02-2011, 14:44
byteit101's Avatar
byteit101 byteit101 is offline
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
no team (The Cat Attack (Formerly))
byteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of light
Window>preferences>FIRST downloader and enter you team, the file is (project dir)\PPC603gnu\Debug\Something.out (or something like that)
close that, and go to FIRST>Deploy
Bubble Wrap: programmers rewards
Watchdog.Kill();
printf("Watchdog is Dead, Celebrate!");
How to make a self aware robot: while (∞) cout<<(sqrt(-∞)/-0);
Previously FRC 451 (The Cat Attack)
Now part of the class of 2016 at WPI & helping on WPILib
Unread 16-02-2011, 15:04
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
Bongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond reputeBongle has a reputation beyond repute
Send a message via MSN to Bongle
I believe the post above will solve your problem.
Background:
ELF refers to "Executable and Linkable Format". WindRiver is asking "hey man, where can I find the actual binary code to put on the robot?". The file you're inputting there (the .out file) is the binary code for your robot software, and is (I believe) ELF format, despite the .out extension.
