Go to Post Everyone knows the best way to lose weight is to turn the robot upside down, shake vigourously, and throw away anything that falls out. - Mark Hamilton [more]
Unread 16-02-2011, 09:02
philso philso is offline
Mentor
FRC #2587
Rookie Year: 2011
philso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond reputephilso has a reputation beyond repute
noise from CIM motors driven with Victor controllers
Hello
I am a first time mentor working with a team where the members are competing for the first or second time.
Can anyone confirm that the growling noise we are getting from the drive motors at "low throttle" is normal?
The main drive motors are a pair of CIM motors. The motor controllers were recently changed from the (black) Jaguars to the Victor controllers. There was no perceptible noise when using the Jaguars. Some of the team members are worried about burning up the motors or controllers because of the noise.
I found some threads (such as http://www.chiefdelphi.com/forums/sh...ad.php?t=83973) indicating that the switching frequency of the Victors is about 150Hz whereas the switching frequency of the Jaguars is about 15kHz. Based on this information and my experience doing R&D on 3-phase motor drives, I would expect the motors connected to the Victors to make the noise that I am hearing.
Thanks.
Phil
Unread 16-02-2011, 09:09
Jared Russell's Avatar
Jared Russell Jared Russell is offline
Taking a year (mostly) off
FRC #0254 (The Cheesy Poofs), FRC #0341 (Miss Daisy)
Jared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond repute
Re: noise from CIM motors driven with Victor controllers
What you are describing is perfectly normal for CIMs driven by Victors.
Unread 16-02-2011, 09:24
Racer26 Racer26 is offline
Racer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond repute
Yup, perfectly normal. I expect this is an artifact of 150Hz being well within human hearing range of 20Hz-~20kHz. The 15kHz of the Jags is much higher up the spectrum, and thus many people can't perceive sounds of that frequency (hearing range decreases with age).
Compare this to the high-pitched screech emitted by many older CRT televisions. Children and teens can hear an energized TV like that from rooms away, while adults can't hear it at all.
Unread 16-02-2011, 10:52
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
The high ripple current caused by the low switching frequency of the Vics will cause more motor heating compared to the higher switching frequency of the Jags, for the same motor torque. Unless you are running the motors for long periods at high torques this shouldn't be a problem; the CIMs are pretty rugged.
