Go to Post I know I exaggerated a bit, but NASA put a man on the moon with less processing than some FRC bots. Think about that for a minute. - JesseK [more]
Unread 16-02-2011, 14:02
wdell wdell is offline
AKA: William Dell
FRC #3999 (Shadetree Mechanics)
Rookie Year: 2010
wdell has a spectacular aura aboutwdell has a spectacular aura about
Source Code for Smartdashboard?
Does anyone know if the source code for Smartdashboard is available someplace? My team is asking me about having two cameras, and would be easier, at least for me, to modify Smartdashboard to accept web feeds on two different IP addresses and get rid of the default video than it would be for me to try and figure out how to do it in Labvies.
Unread 16-02-2011, 14:08
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: Source Code for Smartdashboard?
The source is on FIRST Forge.
Unread 16-02-2011, 14:51
byteit101's Avatar
byteit101 byteit101 is offline
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
no team (The Cat Attack (Formerly))
byteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of light
How are you having two cameras? if you have one or more on the switch, you can even use ZomB, which has support for as many cameras as your computer can handle If you drag a camera on, it is by default accepting stuff from WPILib's built in camera. under source, you can change it to MJPEG, and enter the IP address of a camera connected to the switch in the box below. No source changes needed.
Bubble Wrap: programmers rewards
Watchdog.Kill();
printf("Watchdog is Dead, Celebrate!");
How to make a self aware robot: while (∞) cout<<(sqrt(-∞)/-0);
Previously FRC 451 (The Cat Attack)
Now part of the class of 2016 at WPI & helping on WPILib
Unread 16-02-2011, 17:00
AKA: William Dell
Rookie Year: 2010
The radio has 4 ethernet ports, so it can support the cRio, a couple cameras, and our web-enabled popcorn popper
I was asked if it was possible, and there shouldn't be a problem with it as long as I don't use the AxisCamera.getInstance() and stick to using them as web-cams. They don't want to watch both at once, just be able to switch back and forth between them.
I've actually never been able to get ZomB to work, but I'll take another look at it. It's either that or figure out how to modify the default dashboard in LabView (I hate LV).
Unread 12-02-2012, 19:15
patrickviolette patrickviolette is offline
FRC #1318
patrickviolette is an unknown quantity at this point
Can you please post a link to it? All I can find for the source is here: http://firstforge.wpi.edu/sf/scm/do/...SmartDashboard
and that repository requires validation.
Unread 12-02-2012, 19:22
RufflesRidge RufflesRidge is offline
RufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant future
You don't have to be added as a member of the project, you just have to have a FIRSTForge account which you should be able to sign up for with no issues.
