Go to Post Your team will be more of a team and not a group of students who are just building a robot. Instead of being in FIRST, you will be FIRST. - JackN [more]
Unread 16-02-2011, 16:03
l.li l.li is offline
FRC #0612
l.li is an unknown quantity at this point
Wireless Bridge Orientation
Is there any specific way FIRST wants the wireless bridge mounted on the robot?
Like, do they want it mounted horizontally, vertically, or does it not matter?
Unread 16-02-2011, 16:30
kws4000's Avatar
kws4000 kws4000 is offline
Team Mentor - Programming
AKA: Krazy Karl
FRC #2405 (Divided by Zero)
kws4000 is a jewel in the roughkws4000 is a jewel in the roughkws4000 is a jewel in the roughkws4000 is a jewel in the rough
Re: Wireless Bridge Orientation
Its likely listed in the rules somewhere, but....
Just keep the lights easily visible and cords/switch accessible and likely easily removable (velcro). I just don't recommend hanging it upside down.....
Mentoring:
1) Educating students on the ability to learn and have fun at the same time.
2) Giving back to those who made you who you are.
2009-2011 Student 2405 Electrical/Programming & Asst. Captain
2012-???? Mentor 2405 Programming/Jack-of-all-Trades
Unread 16-02-2011, 17:11
EricH's Avatar
Happy Birthday! EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Actually... it isn't listed in the rules. Pick an orientation that works.
However, the lights do need to be visible (<R53>). If they are not visible for some reason, the field crew cannot diagnose what's wrong when your robot decides it's not going to work on the field.
Also, visible does not mean kinda sorta if you do a headstand inside the robot with your feet on the floor outside the robot. Ideally, you should be able to stand a few feet away and see the lights. Not quite practical, maybe, but if seeing the lights involves "unnatural" body positioning or being inside the robot, expect that you'll need to reposition.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 16-02-2011, 18:19
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
In addition to Eric's statement about visibility (this is very important for your happiness) please do not bury the DAP-1522 down in the guts of your robot next to motors, metal (especially steel) or near the external frame where it can receive damage. There are two antennas mounted inside the case to allow maximum connectivity. These antennas can be detuned by surrounding objects and the electronics can pick up external electrical noise that will make communications difficult. Make sure it is secure on the robot and that the power input is protected so it doesn't fall out. A simple wire tie holding it in place is usually sufficient.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 16-02-2011, 18:32
MagiChau's Avatar
MagiChau MagiChau is offline
AKA: Michael Chau
FRC #0085 (B.O.B. (Built on Brains))
Rookie Year: 2010
MagiChau is just really niceMagiChau is just really niceMagiChau is just really niceMagiChau is just really nice
In the 2011 FRC Inspection Checklist under Electrical it states "Robot Radio - the wireless adapter must be powered via the KOP +5 volt power convertor which must be powered by the dedicated +12 volt connector on the PD. Radio must be mounted so that it's LEDs are visible<R38.B & R53>"
Unread 16-02-2011, 18:52
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
If you're mounting it on one of it's sides, there is only one side without something on it, LEDs, connectors, or lone button.
Other than that, mounting it flat is probably the best bet.
Unread 16-02-2011, 23:45
Dale's Avatar
Dale Dale is offline
Head Coach & Mentor
AKA: Dale Yocum
FRC #1540 (Flaming Chickens)
Team Role: Coach
Dale has much to be proud ofDale has much to be proud ofDale has much to be proud ofDale has much to be proud ofDale has much to be proud ofDale has much to be proud ofDale has much to be proud ofDale has much to be proud ofDale has much to be proud of
I haven't opened one up but the bridge is designed to sit flat on a table. That would lead me to believe its antennas may have a better pattern that way than if you mounted it vertically. Pure speculation on my part, however.
2016 PNW Championship Chairman's; 2016 Winner Oregon City District, 2015 PNW Championship Chairman's; 2015 PNW District Engineering Inspiration; 2015 PNW District Finalist; 2014 PNW Championship Chairman's; 2014 Championship Innovation in Controls; 2013 Chairman's (Oregon); 2013 Finalist (OKC); 2012 Winner (OKC); 2012 Chairman's (OKC); 2012 Woody Flowers (Oregon); 2011 Volunteer of the Year (Oregon); 2011 Finalist & Captain (San Diego); 2011 Innovation in Control (San Diego); 2010 & 2007 Chairman's (Oregon); 2010 Regional Champions (Colorado); 2010 Innovation in Control (Colorado); 2009 & 2008 Engineering Inspiration (Oregon); 2008 Regional Champions (Oregon); 2007 Regional Finalist (Oregon); 2005 Rookie Inspiration (PNW)
Unread 17-02-2011, 00:00
BornaE's Avatar
BornaE BornaE is offline
FRC #0842 (Formerly 39)
Rookie Year: 2007
BornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant future
Mount it however you want with three considerations.
Make sure LED's are visible.
Keep it away from any metallic parts. Radio waves do not propagate through metals and get distorted by them.
The D-link is not rated for normal shocks that happen on an FRC robot. mount it to the chassis with some shock absorbing material.
-Borna Emami
Team 0x27
Unread 17-02-2011, 00:10
nitneylion452's Avatar
nitneylion452 nitneylion452 is offline
AKA: Joe Lee
FRC #3167 (Environmental Tectonics Crusaders)
Rookie Year: 2010
nitneylion452 has much to be proud ofnitneylion452 has much to be proud ofnitneylion452 has much to be proud ofnitneylion452 has much to be proud ofnitneylion452 has much to be proud ofnitneylion452 has much to be proud ofnitneylion452 has much to be proud ofnitneylion452 has much to be proud of
Could you post the link for the check list? I've scoured the FIRST site and haven't been able to find it. (Though I may just not know where to look.)
Unread 17-02-2011, 06:05
MagiChau's Avatar
AKA: Michael Chau
Rookie Year: 2010
The checklist is actually in the manual section as a link right under the link to the Robot Section.
MANUAL PAGE: http://usfirst.org/roboticsprograms/...nt.aspx?id=452
INSPECTION CHECKLIST: http://usfirst.org/uploadedFiles/Rob...cklistRevX.pdf
